Old 11-17-2005, 10:39 PM   #1
swb70
Question swapping parts..
Found a complete parts truck for my 70. Going to swap 6 for the 350, and install ps/pb. Should I also swap radiator. Will the motor mounts swap out or do I need new ones. Will I need to swap the steering column in order to install ps. Will the 350xmission bolt right in. I know these are a lot of ?? but I guess
the main one is, will all these parts from a 1972 fit/bolt on/easy onto my 1970.
swb70 is offline   Reply With Quote
Old 11-17-2005, 10:52 PM   #2
matt67350
matt67350's Avatar
Re: swapping parts..
Most everythng will bolt in. You don't need to change the colum, unless your going from standard to auto. Tell us more about your project so we can help.
ie: motor, trans, 6-lug or 5-lug swb or lwb,a/c non-a/c, gauges or just lights.
These things will help the answers to your ?'s
Matthew
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
