Hi people, new member and first post. I need help with a power steering swap. My truck is a two wheel drive LWB w/350 and 3 on the tree. I really want to change from manual to power steering. Scored the pump,brackets hoses and box from a 70 C10. What else do I need? Besides the crank pulley and belt?
What does it take to do this swap? Thanks for the help. ![]() ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Power Steering swap on a '70 C10
Along with the parts listed above, you'll need a power steering pitman arm and the coupler for the input shaft on the box that the rag joint bolts to.
Thanks for the info, but is it a bolt in operation or does it need "help" to bolt up?
No mods necessary, it's a bolt in.
