Old 11-18-2005, 02:38 AM   #1
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Need part number
Hopefully someone can give me part number for the upper or lower control arm frames shafts. Mike (Swervin Ervin) replaced his with the front end rebuild when he went back to rubber bushings. Anybody still have those numbers and are they the same for 73-80? Santa has already started ordering parts for Christmas and I need everything I can ask for
Also should these be replaced while I'm there or should they just be checked out? If I remeber right they're $$$
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 11-18-2005, 06:02 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Re: Need part number
Brandon,
I haven't replaced the control arm shafts. I haven't went back to rubber bushings yet either.
Unless your shafts are bent or messed up in some way, there is no use in changing them. Only reason would be if you needed offset shafts because of dropping.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 11-18-2005, 11:02 PM   #3
Prerunner1982
Prerunner1982's Avatar
B are you thinking of when he had a loose bolt on his control arm shafts?
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 11-19-2005, 12:48 AM   #4
79BIG10
79BIG10's Avatar
Mike I thought you changed them out for the ride quality and you saw a broken bolt. I must be losing it over here. Not enough blood flowing up to the brain
Jon- You're probably right. I just remember him replacing a bolt on the front end and having to go to the dealer and get it.
Old 11-19-2005, 12:59 AM   #5
swervin ervin
Yeah, I had one of the bolts break and had to buy it from the dealer. I decided to replace all four on the upper arms.
If the blood isn't going to your brain, where's it going?
Old 11-19-2005, 01:03 AM   #6
79BIG10
79BIG10's Avatar
That's what I was thinking that you replaced and was wondering if I would need to replace them. While I'm thinking about it was there anything else you bought for you front end rebuild besides the kit from Performance Suspension? I just ordered it today and I'm buying front springs as well. Other than brakes, bearings, races, hoses, and grease is there anything else you might think of that might need replaced? I was going to look at another pitman arm while I was there as well.
BTW: This is a family site so I'll stay quiet on that.
Old 11-19-2005, 02:08 AM   #7
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
79Big10-
Replacing the pitman arm is a good idea.
When I went through my front end, I also replaced the upper and lower ball joints on both sides since one of the lower ball joints were shot. I also replaced the tie rod ends since they weren't that much more. I ended up replacing the centerlink, but I don't think that mounting openings on it were worn enough to really warrant replacing it.
BTW, while I was at the local auto parts store picking up a can of 'power blaster', I also borrowed few of their front suspension tools to help disassemble the front suspension components.
Good luck.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 11-19-2005, 03:22 AM   #8
79BIG10
79BIG10's Avatar
I didn't think about the centerlink but I will do that as well. Here's a list of what the kit has that I ordered.
Chevy 2 Wheel Drive Kits contain:
Upper & Lower Ball Joints
Inner & Outer Tie Rod Ends
Idler Arm
Complete Upper & Lower Shaft Assemblies (Where Applicable)
Graphite Impregnated Polyurethane Bushings*
Upper & Lower Control Arm Bushings
Sway Bar Bushing Kit with Brackets
Polyurethane Tie Rod Boots
*All Black Bushings Are Graphite Impregnated Polyurethane
Here's the link as well http://www.performancesuspension.com/truckfek.htm I priced the items seperate and it was cheaper to go with this kit. He uses Moog parts on everything but the bushings which are the Energy Suspension ones. I've got the rear leaf spring set already but need to install them as well if I get a chance on the rear.
Thanks for the heads up on the power blaster. I'll try to that along with some cleaner to get all the grease off the a-arms, bolts etc. to get ready for primer and paint.
Old 11-19-2005, 08:49 AM   #9
swervin ervin
I replaced the pitman arm also. I didn't replace the center link of the tie rod. The holes never looked worn enough to warrant it.
