Premium Level Member
77 BLAZER...Where is the frame VIN #$%^&
I need to go to DMV and they want a second location for the VIN. I have no idea where it is on the frame. I've checked on the frame(pass and drive) in engine compartment. PLEASE HELP ASAP. I gotta go today
69 K5 CST stock- 350, 4speed ![]() 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, |
K5Camper
![]() Join Date: Mar 2004
Re: 77 BLAZER...Where is the frame VIN #$%^&
Why is the DMV asking you? They should have a book of some type that has the locations of the vin stampings. If they don't the cops should as they use the vin stampings in cases of stolen cars that had the vin plates swapped.
I don't remember for sure but I thought I was told it was stamped on the TOP of the left (drivers) side frame rail. I thought it was under the body though so it's almost impossible to see. Need a dentist mirror to see it at least. |
#3 | |
Here is the kicker....the k5 is a CA truck as was registered here before I took it to NJ....idiots. Its in there system!!! ![]()
Happy to be here
![]() Join Date: Mar 2000
This subject came up recently in the 73-87 forum. It never was confirmed but take a look here-More info
Well the number below the door on the frame is not a Vin#. I've cleaned the whole frame in the engine compartment to find nothing. At this point, its gotta be under the cab. I'll let the CHP(Ponch and John) find it since its their rule that
DMV find two ![]() ![]()
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
It should be on top of the framerail under the seat area (or flat part) if you can't find it anywhere else.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
I have found the vin number in differnent locations, on the passenger side top frame flange. From the front to the center of the frame.
This one (77 K5 frame) is at the engine cross member.
Real Trucks are Built not Bought Building: 1981 GM SB LowRider 1985 GM K3500 3+3 1981 GM K2500 SSB 1980 GM K2500 X-BC Hydro 1979 GM K3500 3+3 1976 GM K5 Blazer 1970 Custom 10 http://bc4x4.com/ |
#8 | |
them know the info provided here so they can be sure. The funny thing is that I'm bringing the truck from one state into CA, but it was registerd most of its life in CA already before leaving state for a few years....so this is just RED TAPE!
