Better late than never
![]() Join Date: Dec 2001
Clutch linkage squeak fix
I don't know about others, but my clutch linkage in the cab has always squeaked. Last weekend I eliminated the causes by replacing the clutch shaft bushings, which I ordered from LMC. They were easy to replace by working through the removed gauge cluster opening. I was surprised that the 35 year old bushings were not in too bad condition though.
The biggest improvement was installing a brass bushing on the clutch arm, where it connects to the pushrod that goes through the firewall. I bought a 3/8 ID brass bushing, cut it to length, and drilled out the arm hole to 1/2". Shifting is now smooth and quite. This weekend I will do the same fix where the pushrod connects in the engine compartment.
1970 C/10 SWB Stepside |
~Rest In Peace~
Re: Clutch linkage squeak fix
check that rod out real good mine as worn spot on the rod end like where it sits in the bracket
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
Mine does too. I can't imagine why chevrolet built these without bushings there in the first place?
