hyd clutch pedal assembly from late model chevy truck?
Have any of you installed a late model hydraulic clutch pedal assembly in any of your trucks. I have a nv 3500 for my 70 and I am going to a junkyard next week to try to find a pedal set to use or graft the hyd clutch part over to my original pedal assembly.
Does anyone know if a tri 5 (55,56,57) chevy pedal assembly will fit in our trucks or perhaps an impala (thinking about the fact that impala wheels are 5 on 5 like a truck wheel pattern). thanks for your replies
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
Post Whore
![]() Join Date: Feb 2000
Re: hyd clutch pedal assembly from late model chevy truck?
I am using a hydraulic clutch and hydroboost system from a 1989 1 ton (old body style) on my 69 K20. I looked at swapping the pedal assembly but that would have taken a lot of custom work and was very simple to just mount the pushrod to the existing pedal assembly. Here is a link to info on my install.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 11-19-2005 at 10:25 AM. |
thanks for the reply, when you say later model in your link what years are you referring to?
thanks for the link as well
Post Whore
A 1989 can be a new body style or the old body style. The old body style is the one I had the master needs the shim. The new body style 89-up doesn't need that shim.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
thanks for your information, i guess not many guys have done this.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Yukon thanks for the link should work for a 2wd also correct with the exception of the hydroboost..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#7 | |
Where's my beer?
Board member Huck from KY was the first in this board to do this kind of swap, he did this a few years back and has since sold the truck I believe, I personally saw that truck when I first met him (sweet truck) and it was hard to see or know that the ol' truck he was driving had in fact a 5 speed tranny in there as he hid the hyd. clutch under the brake booster )I wouldn't had known if he hadn't said anything) you may want to send him a pm and ask about the particular setup he had in the truck back then. ![]() BTW: Huck's truck was a 2wd if it matters any ![]() |
thanks,chevy fatman, just been little response so far. thanks for your resposne, my truck is a 2wd, by the way.
Post Whore
Both the hydraulic clutch and hydroboost will work on a 2wd - the donor truck was a 2wd.
I need to get some pics of the bellhousing added to my link so people can see it also.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 11-20-2005 at 11:17 AM. |
1972 GMC 2006 GMC
I put an aftermarket Tilton Hydraulic clutch in mine. Looking good so far with the Richmond 6 speed....Truck is not done yet so I havnt tested it out. Very nice components though.....I had a 88 Chev, truck that had a hydraulic clutch that I could have modified something similar, But I wanted to run the Hydraulic Bearing not the Slave this time......It eliminates the pivot and arm as well. Looks real clean!!
kcw, could you post a link or some more info, could this work with the nv3500?
I used a hydralic throw out bearing makes it alot easier to hid any resivor you use Ill try to get the name posted of what the throwout bearing is
#13 |
![]() Join Date: Sep 2005
I'm about to install a NV4500/Twin stick np205 in my 67 and was going to use a hydrolic setup.This perticular one is a 99'+ bellhousing with the left side setup.Will an older Hydraboost work with my setup? Is it fairly simple to setup?
01 2500 Duramax,6spd,4x4,Not stock. Estimated 550rwhp/1100rwfp on fuel only. 03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only 67 K10 in many pieces Little Brothers truck 67 K20 Cummins 12V/NV4500/205, D60/Eaton w/ Detroit,37" Xterrains,crossover steering, Future plans,Twins and lots of fuel. |
#14 |
I installed a 5 speed with hyd clutch setup out of a 96 1/2 ton chev truck. I installed the clutch master cylinder on the firewall behind the power booster--just more center to the body on the inside of the brake assembly. I used the stock original brake/clutch assembly and fabed a bracket to attach the clutch push rod to. This unit has the internal hyd throwout bearing. The unit worked well but needed a bit more pedal pressure then I would have liked. Also the aluminum transmission was designed for an electronic sensed speedo which I never addressed. All in all, it is a nice swap especially the OD 5th gear. In my experience, if a mechanical clutch will work, I would prefer avoiding hydraulics as they tend to be less forgiving---ie. leaks, bleeding, adjusting issues, etc. In one case, my clutch master cylinder let loose from the firewall and I had to drive the truck 40 miles shifting without the clutch--via rpms. Huck
#15 |
huck, what you done is basically what i am doing, except i do not have the luxry of a complete donor vehicle. i am piecing together stuff as i can and
i appreciate your response and information. my particular nv3500 has a integral bellhousing, so that complicates things a little. so based on your response you used your old original clutch/brake pedal assembly and adapted the hyd clutch to it. is that correct?
