Dont know what to do!!??
I have an 87 GMC and a 89 Chevy, the 89 is my daily driver, I want something else to drive so I can work on the 89, I can drive the 89 and work on the 87 to make it a daily driver. Heres the problem, the 87 needs a motor, its got a TBI 262 in it, would it be cheaper to put a 350 in with a carb or go back with the V-6 and TBI? What would the gas milage diff be? The trans is a rebuilt TH400 with under one mile on it. My question is do I fix the 87 so I can drive it or sell it for the money to work on my 89? How much would it cost to put a motor in the 87? The 87 has a perfect rust free body and no dents but needs to be painted and it only needs a dash pad to be perfect inside, maybe some better looking door panels or just paint them. So is the 87 worth keeping and fixing? Thanks
Re: Dont know what to do!!??
it depends on what you want to keep but yes the 87 i worth keeping IMO i would def. have another veh. to drive will fixing up one of them
square body trucks an addiction or an investment either way they consume all my extra time and money |
Web Wheeler
IMO its hard to DD a project vehicle. Drive the 87 while you fix the '89.
Find a used v6 runner with decent compression you can shove in there. Pick an 86-95 version, and if it has a balance shaft, make sure it comes with its own TBI intake (it has a flat bottom for shaft clearance). Watch out for the S10 2wd oil pan... it may not fit your suspension.
'66 C10 longstep - Clifford equiped '84 C20 Suburban 6.2L - awaiting 4x4 conversion '91 V3500 Crewcab - awaiting diesel swap Last edited by u2slow; 11-21-2005 at 01:46 AM. |
Right turn Clyde
Pictures would give us a better idea of the value for the 87 truck.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
