Old 11-19-2005, 01:20 AM   #1
tripleblack
short sell Ford stock
Dashboard Instruments & Gauges help....
My 69 GMC has the dashboard instruments without optional gauges and tachometer.... you know, the one with 3 holes, speedometer, blinkers, and fuel gauge. I want to convert mine to the one with 7 holes (optional gauges and tach). I was wondering if it as easy as simply swapping? I cant imagine it being that easy considering the additional gauges need respective wiring or whatnot. If not that easy, what exactly should i do to make the swap a success if it even can be possible without going to tremendous lengths. Thanks for your help once again.
tripleblack is offline   Reply With Quote
Old 11-19-2005, 03:06 AM   #2
Striker169
Car O'Holic
Striker169's Avatar
Re: Dashboard Instruments & Gauges help....
wait so you dont have guages but you have a tach? PICS?
Striker169 is offline   Reply With Quote
Old 11-19-2005, 06:00 AM   #3
tripleblack
Its kind of hard to explain but put it as simply as i can, i have the stock setup with a speedometer, and fuel gauge. There is no RPM meter, temp gauge, battery/amp gauge, or oil pressure gauge. I am not next to my truck this moment or i would post pics.
Old 11-19-2005, 06:09 AM   #4
OhioDan
OhioDan's Avatar
Thumbs up Re: Dashboard Instruments & Gauges help....
You'd have to install a new in- cab wiring harness for gauges, plus a gauge dash panel. Kinda costly, unless that's what you want. Many on here have dash panels for sale or trade. I'd definitely get a new dash wiring harness for gauges, rather than try and swap a used one in. Just my $ .02 .
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 11-19-2005, 06:10 AM   #5
chops333
theres some info on gmc pauls truck on this subject
chops333 is offline   Reply With Quote
Old 11-19-2005, 06:52 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
To do it properly, you'd have to replace the underhood harness..and maybe the underdash one too.
BUT... like chops said, www.gmcpauls.com
