Old 11-19-2005, 03:41 AM   #1
HeavyD
HeavyD's Avatar
Need clarification re: my tilt column for sale
I have a board member interested in my column, but he is concerned it might be a converted van unit because of the clipped plug wires. To my knowledge the stubby splined end would indicate a true truck tilt, and I see no evidence of safety switch relocation, but I thought I would see what you board members thought. What do I have?? Thanks.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 11-19-2005, 06:56 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Need clarification re: my tilt column for sale
looks like the real deal.
The harness is probably fropm some one installing a replacement turn signal switch and not having an adapter to use.
Old 11-19-2005, 08:20 AM   #3
70GMCer
70GMCer's Avatar
Looks right to me also.....The van tilts have the neutral switch further up on the column. At least mine did.......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-19-2005, 09:21 AM   #4
You`re right,it`s a truck unit with questionable wiring.As you described in your listing.
Old 11-19-2005, 01:02 PM   #5
jsbgump
Gone Fishing
jsbgump's Avatar
Looks like a real truck one to me.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 11-19-2005, 01:03 PM   #6
HeavyD
HeavyD's Avatar
Thanks everyone.
Old 11-19-2005, 01:34 PM   #7
Rod
Take a look at the neutral safety switch and see how its hooked into the switch..if its a tab thats been folded back from the original inner tube into a grooved switch tab ...well then its original. It looks original to me from what I see here. Rod
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-19-2005, 04:18 PM   #8
69TowRig
My truck's original column had the hack-n-tap done to the harness. Someone replaced the column switch but couldn't find the half-moon style plug, so they hacked it. That's what you have there.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 11-19-2005, 08:59 PM   #9
Rod
Some people just dont know how to get the switch plug through the column..so they hack it and attach it after...thats what I see there. So I agree with 69TowRig on that.
Old 11-19-2005, 09:35 PM   #10
70short/step
70short/step's Avatar
If you ever have seen the van and truck tilts together would never forget the differences. Like said above....The short splined shaft is a truck and the position of the neutral safety switch is also a truck. Maybe we need to get someone who has a pic of the two side by side and keep it posted in a sticky. Heck there might be a pic in the FAQs
P.S.
I just installed a van tilt in my truck a couple of weeks ago so I know the one you have there is a truck!
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 11-19-2005, 09:45 PM   #11
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Left to right:
Van/Van with N switch in PU position/real 71-2 PU.
PICKMUP is offline   Reply With Quote
Old 11-20-2005, 03:23 AM   #12
HeavyD
HeavyD's Avatar
Hey, that is a good pic for comparison. Thanks again for all the help guys.
