Old 11-19-2005, 08:58 AM   #1
mike nutt
69fatmotor
mike nutt's Avatar
69 pics from new guy
pics of my '69 c\10 shortbed project of about 7 months now . as you can see from the pics it has several doner truck parts on it.the frame also has several mods. more pics to come with more progress . comments or sugesstions welcome.
mike nutt is offline   Reply With Quote
Old 11-19-2005, 09:04 AM   #2
mike nutt
69fatmotor
mike nutt's Avatar
Re: 69 pics from new guy
more pics
Old 11-19-2005, 09:11 AM   #3
mike nutt
69fatmotor
mike nutt's Avatar
more pics
more pics
Old 11-19-2005, 02:24 PM   #4
llegos
Re: 68 pics from new guy
lookin real good. is she gonna be a step of fleet?
-Steve
llegos is offline   Reply With Quote
Old 11-19-2005, 03:28 PM   #5
70c10swb
no brain no headache
70c10swb's Avatar
coming along great
whats the drop? what engine are you droping in?
1996 GMC Sierra z71
1970 SWB 2wd (project)
70c10swb is offline   Reply With Quote
Old 11-19-2005, 03:58 PM   #6
HeavyD
HeavyD's Avatar
Truck looks really good. Since you asked for suggestions, I suggest painting it the original orange. What are your color plans? What does the glovebox say the color is called?
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 11-19-2005, 08:15 PM   #7
mike nutt
69fatmotor
mike nutt's Avatar
i've got a stepside bed off a '94 that i'm planning on using. i will shave the rear steps add a roll pan also rework the wheel wells to match the front ,but plans could change if i find a good useable correct fleetside.
Old 11-19-2005, 08:30 PM   #8
mike nutt
69fatmotor
mike nutt's Avatar
Originally Posted by 70c10swb
coming along great
in the rear i've used a 6" early classic enteprizes kit with supertrack bar, shock relocator, shocks and axle saddles the rear axle is from an '86 with 4.11 and posi. the front frame was z'd 3" with the complete front cross member and suspension from an "86 c\10 added with 2" springs . also in th rear the trailing arm crossmember was flipped over and 4" rings welded in for exaust to go through . there will be no ground clearance issues on this truck as with my last truck. and on the trailing arms the seam were welded up for strength
Old 11-19-2005, 08:33 PM   #9
mike nutt
69fatmotor
mike nutt's Avatar
coming along great
the engine is a hot little 396 backed by turbo 400 with 2800 stall
Old 11-19-2005, 08:40 PM   #10
mike nutt
69fatmotor
mike nutt's Avatar
the sticker in the glove box simply reads orange/white. my color aren't final yet, but i'm thinking a candy brandy wine over silver twotone ,or the orange found on the '04 lamborgini marcialorgo ,yes i know thats not spelled right, but thats my two picks so far.
Old 11-20-2005, 02:11 AM   #11
BowTieMan
BowTieMan's Avatar
Nice truck. Can't wait to see it done. What size rims and tires are those. I love the look of those cragars!
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 11-20-2005, 05:39 AM   #12
HeavyD
HeavyD's Avatar
What is the paint code number on the sticker? Is it 516? Thanks.
Old 11-20-2005, 08:56 AM   #13
mike nutt
69fatmotor
mike nutt's Avatar
the rims are 15" x 8" with 4" backspacing alll the way around. front tires are255/60/15 and rear is 295/50/15. rear needs to 10" wide with 6" backspacing.
Old 11-20-2005, 01:10 PM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That rear frame crossmember is in backwards.
The big hole is for the light wiring harness, and it should be on the driver's side of the truck.
Nice big shop by the way....
Old 11-20-2005, 01:24 PM   #15
mike nutt
69fatmotor
mike nutt's Avatar
tx firefighter, that crossmember has been flipped around correctly and moved foward slightly to mount the fuel cell. previous owner had the crossmember flipped around with some sort of car gas tank rigged in it , also cut a big hole in side of the frame rail filler neck.
Old 12-10-2005, 09:02 PM   #16
burban70
burban70's Avatar
I'm in Birmingham and was wondering if you still had those parts trucks available. I'm doing a '68 longbed.
burban70 is offline   Reply With Quote
Old 12-13-2005, 12:18 AM   #17
67chevy2wd
67chevy2wd's Avatar
Nice pickup, but I was awestruck by your shop it is really clean. What size shop is that if you don't mind me asking?
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
