The LuvShack Garage
My buddy is a mechanic and he was telling me about this yesterday,
is he full of it or what, since the ROADSTER will not need A/C it may just be worth it to try it, would keep the install a lil cleaner since I wouldn't have to figure out a place to mount me a pump, thoughts?
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Project92 SWB stepside
Re: Anyone ever used there A/C compressor for air bags
I have heard that somewhere.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
#3 | |
The LuvShack Garage
Really? Hmmmm if it would work I could tuck everything outa site ![]()
Happy to be here
![]() Join Date: Mar 2000
You may have heard of "engine driven compressors" that are commonly used to run air systems for bags on 2wd's and air up tires, etc on 4wd's. These are actually a/c compressors. They were OEM on various older veihicles like Ford, and Jeep. The are a very square compressor unlike the typical round a/c compressors.
There is a major difference between them that makes them compatable for this application. The York compressor have a sealed oil reservoir to lubricates the compressor. Most round (or radial) compressors are designed to run a wet system. They require oil to be in the refrigerant system for lubrication. Due to this design, the common GM compressors will not work. If you want to run an engine driven compressor, you will have to adapt a York compressor to your motor..... ![]()
What they use for an air pump, 4X4's, is the chrysler style A/C compressor. It can be converted easily but i didn't pay a lot of attention how. Jeep magizine probably has the tech article, or look under off road boards too.
Not to try to sell you anything but I have that style compressor, it was used for add on air in the old days before the sanyo compresser. I have it on a 72 burb with P/S. I am going with factory A/C. Compressor with brackets and pully's. Pm me if interested.......... Thanks, Steve |
The LuvShack Garage
Thanks trux, I too have heard the GM one won't work, the Chrysler
one mentioned above is the one that was reccomended to me also.
Trucker.
You need a York 210 or 209.
The Sanden style pumps that are on GM's are the ones everyone is referring to. |
Visit Kilby's site: http://www.kilbyenterprises.com/ or http://www.onboardair.com for lots of tech info and ideas.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
