Old 11-20-2005, 12:07 AM   #1
Green Machine
Green Machine's Avatar
Dual exhaust for my 88 ???
Heard the baffles rattling in my muffler today so it's geting time for some exhaust work. Body isn't to good so I don't want to spend alot. Has stock 305 TBI and single exhaust with cat. Does anyone make an "offroad" dual exhaust kit that I can bolt on ? Or would a single exhaust minus the cat do pretty good ? I would like to make it just a little louder than stock., and remove some restrictions. Should I just have the local muffler shop build me some duals and /or fix the single ? They said one time if the cat just happens to fall off in my driveway they could, well, "fix" that. Thanks in advance.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-20-2005, 12:18 PM   #2
Z16
Re: Dual exhaust for my 88 ???
Pretty much any bolt-on system you can buy is gonna be a cat-back. They are all really good mandrel bent systems that usually cost about the same as a muffler shop bent system, and are very easy to install at home. Look at Flowmaster or Gibson. If you do go with a cat back system, have the muffler shop build a bolt in piece to replace it in case your state does crackdown on emissons. If you do get a shop to build a system, try and find one that can do mandrel bending. It is worth a little extra power and mileage.
Z16 is offline   Reply With Quote
