Old 11-20-2005, 12:10 AM   #1
drkyello
Electric tailgate window question
i have been looking for a electric tailgate for my blazer and have ran into a few at the junk yard, but i am not sure if the window motor works, or the window is rolled all the way up and i cannot bring the window down to even open the gate. is there a way to roll down the window without hooking up a battery to the car? if i connect a car battery to the wires direct to the window motor is it too much volts? any help would be appreciated
drkyello is offline   Reply With Quote
Old 11-20-2005, 01:26 AM   #2
longhorn71
longhorn71's Avatar
Re: Electric tailgate window question
i hooked mine direct it get the window down and it never hurt the motor in it
longhorn71 is offline   Reply With Quote
Old 11-21-2005, 08:38 PM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
One way to get the window up or down without power is to take the cable off of the motor and chuck it up in a cordless drill. The drill should have enough torque to drive the window up or down and give you an idea of the actual mechanical portion of the regulator is OK. At that point you could remove the assembly and take it up to the office to power it up and make sure the motor works.
Most yards I've been to will have a battery to test with or send you to the dismantling shop to test it there.
Zoomad75 is offline   Reply With Quote
Old 11-22-2005, 12:40 AM   #4
a28doc
'87 V20 4x4
a28doc's Avatar
i slit the wire insu;lation and hooked a bat charger upto it and worked fine for me
Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
Old 11-25-2005, 02:07 AM   #5
blaserman
blaserman's Avatar
With all the problems that seem to popup with them I would stay with the old crank type. Sure wished I had swaped mine out.
This is my best friend
blaserman is offline   Reply With Quote
Old 12-04-2005, 12:09 PM   #6
garptah
I had a problem with mine and it turned out to be the cable going from the motor to the crank mechanism. You can remove the cable from the crank side and slide a small flat headed screw driver into it and it will allow you to roll it up and down. Cable was 32 bucks from the dealer.
garptah is offline   Reply With Quote
