11-20-2005, 11:13 PM | #1 |
Cooling System
I have a quick ? for you guys. When should I be able to see the water pumping through my radiator. I can start my truck and remove the radiator cap and my coolant is motionless. Also it seems that when I put my cap on the coolant comes out the reserve hose. There aren't any signs of water pump malfunction. Nor does the truck seem to be running out. I'm just tired of having to put water in every morning cause I indicated when the cap is on the coolant is coming out.
11-20-2005, 11:21 PM | #2 |
its all about the +6 inches
Re: Cooling System
you are overfilling the rad. The coolant level is supposed to be 1 to 2 inches BELOW the cap.
Coolant movement should start when the T-stat opens. If y9our pump wasn't working, you'd know it. Everything sounds fine to me. |
11-20-2005, 11:27 PM | #3 |
~Rest In Peace~
Re: Cooling System
change your thermostat first and see if it open up before you replace the water pump what condition is the water in ? rusty? green how many miles on the truck or engine ?
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
11-21-2005, 12:27 AM | #4 |
Re: Cooling System
It is a 1971 chevy 4x4 shorty. It has a 350 generation 1 vortec for a 1988-1995. Don't know miles think is fairly new but I just bought the truck and that was what was in it. It is clear water that is coming out cause until I resolve this problem i'm not going to keep putting anti-freeze in it.
11-21-2005, 02:29 AM | #5 |
Thats the Hillbilly way
Re: Cooling System
I always like to start with the easy thing first , I would get a new radiator cap , then change the thermostat next .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
11-21-2005, 10:45 AM | #6 |
Black 72 Chevy
Re: Cooling System
djtlaz, I use to have the same problem with my truck. What I did was to install a Coolant Recovery Tank and problem solved.
11-21-2005, 02:15 PM | #7 |
computer illiterate
Re: Cooling System
you probably have the wrong radiator cap
72 2wd blazer 72 swb 4x4 |
11-21-2005, 04:32 PM | #8 |
Re: Cooling System
wrong rad cap won't cause exsesive coolant to come out. It'll just come out sooner.
How low does the water level drop? |
11-21-2005, 05:39 PM | #9 |
computer illiterate
Re: Cooling System
thats strange, because somehow i lost my radiator cap. so i went and bought a new stant for my 2wd blazer (daily driver) and it kept running low on coolant. everytime i would shut it off it would run out of the overflow hose as they gave me the wrong cap (vato zone). because when i went to get another figuring that was the only thong that was changed they gave me a different part number for a stant cap at parts america and it is all good now
11-21-2005, 06:17 PM | #10 | |
Keep On Truckin'
Re: Cooling System
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
11-21-2005, 07:05 PM | #11 |
Re: Cooling System
i too am of the opinion that nothing is wrong and you're just overfilling the rad when it's cold// buy a dozen caps and as many pumps and hoses as you care to if you overfill it it will still run out on the ground
with the rad cap off let the truck run for a minimum half hour then adjust level to about 1inch below the filler put the cap on and you won't have the problem anymore
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 11-21-2005 at 07:26 PM. |
11-21-2005, 09:00 PM | #12 |
Re: Cooling System
no chance it has the wrong water pump...ie, reverse rotation vs standard rotation. I dont know if this is even possible on that motor, someone might chime in.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
11-21-2005, 10:59 PM | #13 |
Re: Cooling System
Thanks guys! I will do all that was suggested once I get time. But just to add another note. If the radiator is only suppose to be filled to a inch below the cap then when it drains it should only drain to that level. So times I have to put a cup(32oz) or more in. It was low enough one time that it didn't have enough flow through the heater hose that my heater was blowing cold. I'll start with a radiator cap this weekend. Then I'll try a thermostat that opens fully at a lower temp. Is there a thermostat that is always open? And if not why wouldn't you wan't water flowing through the motor constantly? Thanks for all the help.
11-21-2005, 11:12 PM | #14 |
Re: Cooling System
you want the water in the engine long enough to absorb the heat, then in the rad long enough to disapate the heat.
Running with constant flow will keep the engine way below optimum operating temps...then eventually, it'll run hot and overheat. |
11-22-2005, 08:54 AM | #15 |
Re: Cooling System
So, the TBI motor you have (not a Vortec) should have a 180 degree thermostat in it. It should be a fully closed system, meaning the overflow bottle is crucial, as is the radiator cap.
11-22-2005, 03:05 PM | #16 |
Re: Cooling System
i am having about the same problem, the rad cap is a Stant 330 16lbs with the lever pressure release (Lev R Vent), i fill the rad so i can see the green coolant when the cap is off. when it is completely full (i can see the coolant) the heater seems to work better. am i just being stupid or could i have the wrong cap? if i install an overflow bottle will the system fluctuate the amount that is in the bottle as the system heats then cools down? thanks guys i always learn something from the board.
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat) |
11-22-2005, 07:41 PM | #17 |
Re: Cooling System
The only part of the cap that can be wrong is how many pounds it takes to push it open and let water out of the overflow not sure what you are suppose to use but 14-18lps would be good I would think? Any cap in this range designed for a closed system should work. And unless you have a system set up to recover overflow the bottle will only catch what comes out of the overflow. The overflow is there to let pressure and or fluid bleed off if the radiator builds to much pressure. And one cup is not alot it should be about 1-2 inches below the top. Fill it, get air out, run it let it belch any out it dont want then check it should be a few inches below top then leave it alone.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
11-22-2005, 08:50 PM | #18 |
Re: Cooling System
And if someone can confirm these radiators from our era were never designed to draw overflow back in to the radiator. And if you buy a cap off the shelf or a nice chrome or billit one it is not design to draw over flow back in you would have to get one from a newer style truck right? Not sure how you can tell but it would have to have somekind of vaccum deal. So does such a cap exsits for our radiators?? I just always here people talk about pulling overflow back in and it takes more than just a bottle to do it. With the closed system cap like ours it only lets pressure bleed out to stop the radiator from bursting. nothing goes in? Anyway can someone confirm or enlighten me?
thanks
