Old 11-20-2005, 11:29 PM   #1
matt_field
matt_field's Avatar
wheels and tires 72 swb road and strip truck?
i was thinking like what djracer had... 15x7 up front and 15x10 in the back with 4.5 back spacing and 28x12.5 tires in the back? on centerline telestar wheels.... i want the biggest tire i can get under there with out rubbing. the truck is a coil sprung rear end with trailing arms if that helps any too. any one have pics of somthing in this sort of setup to help me ? thanks!
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 11-21-2005, 12:19 AM   #2
71Dragtruck
71Dragtruck's Avatar
Re: wheels and tires 72 swb road and strip truck?
Mine are 15x12 and 15x6, back tires are 28x14.5's and it is mini tubbed.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 11-21-2005, 12:31 AM   #3
Jayss109
Active Member
Jayss109's Avatar
I want to do the same setup 15x7, 15x10 but i dont want to do any cutting. Anyone know the MAX that will fit with a stock setup? What backspacing? Thanks!!
Jason
________
HotStella
Jayss109 is offline   Reply With Quote
Old 11-21-2005, 08:04 AM   #4
71Dragtruck
15x10 with a 5.5" backspace will fit on the back no cutting. I had 295/50's for tires on with that rim and lot's of room. I had my 28x14.5's on there that have a section width of 13.2 and they rubbed a bit when turning on inclines. They did not rub with the stiffer stock suspension, but with my 4-link the rear pivots alot easier and it rubbed.
Sponsored by:
Hard Candy Customs
Old 11-21-2005, 10:52 AM   #5
ratrod67
ratrod67's Avatar
15X7 front- 15X10 back with 345/55 drag radials. No rubbing or cutting done.
ratrod67 is offline   Reply With Quote
Old 11-21-2005, 11:38 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
It will be difficult to find a 15x7, with a 4-1/2 inch back space. You can get them by special ordering from some places, like American Racing. But, expect to pay a premium for them.
Most of the 15x7 and 15x8's will have a 4-inch back space. The 15x10's could have either a 4-1/2 or 5-inch back space, depending on the wheel.
I'm going with 15x8 6-lug Vette-style ralley wheels on the front, and the same style in a 10-inch width on the back. Plan to use a 275R60-15 on the back and a 225R70-15 on the front.
I asked the tech guys at Early Classic (where my suspension came from) about the back space that I should be running. They say that a 4-inch b/s is good for 15's, but anything larger in diameter should go to a 4-1/2-inch b/s.
Member Nr. 2770
Old 11-21-2005, 11:51 AM   #7
Jayss109
Active Member
Jayss109's Avatar
Thanks guys! Ratrod, are you running 5in backspace on the rears?
________
Blonde Cam
Old 11-21-2005, 01:22 PM   #8
Zumo
Hot Rods For Life
Zumo's Avatar
Yeah what's the setup on the suspension on that truck? Details bro!
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 11-21-2005, 02:56 PM   #9
matt_field
matt_field's Avatar
hey ratrod, what are the specs on your wheels, as far as exacly what they are, thanks! also the tires...
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 11-21-2005, 07:45 PM   #10
ratrod67
ratrod67's Avatar
Thanks for the interest in my truck. The wheels are Centerline Telstars. They are 15X10 with 5 inch backspacing. The tires are BFG drag Radials 345/55/15's. The rear has a 4 inch drop spring and 2 inch block. 6 inch total. The front has 3 inch drop spindles and a 2 inch drop spring. Also has tubular A arms in front. 4 wheel disc brakes.
Old 11-21-2005, 08:09 PM   #11
matt_field
matt_field's Avatar
that thing is sweet!, you have any more pics of it, also dragtruck you have any pics of the tubbing?
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 11-21-2005, 08:20 PM   #12
71Dragtruck
Here are a couple of pics. Ratrod how do you like the tubular arm's, are they lighter than stock? I been thinking about doing something with my frontend, I like the looks of the Fat Man kit, but I want to keep my 5x5 pattern and same width.
Sponsored by:
Hard Candy Customs
Old 11-21-2005, 08:50 PM   #13
ratrod67
ratrod67's Avatar
Yes, the tubular arms are lighter than the stock arms. Not sure how much though. They are Chisholm arms and are good quality.
Old 11-21-2005, 11:56 PM   #14
409biscayne
409biscayne's Avatar
Dragtruck I love those wheel houses , did you build those ? I'd like a set for my 68 . Question : how come you didn't mount the gas tank under the bed ? Too pretty to hide ? How about some engine pics. Tks.
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 11-22-2005, 12:53 AM   #15
71Dragtruck
They are made out of 2 sets of tubs cut and welded together, had them done at the local body shop. Truck is slowly becoming more strip than street, so I wasn't to worried about hiding it, some day plans include an aluminum bed floor. Here is a old engine pic, the motor is now pulled and a new BB 489 stroker is being built. I'll post pics as soon as it is done along with dyno sheets, shooting for over 650 hp and over 640 torque, on motor.
Sponsored by:
Hard Candy Customs
Old 11-22-2005, 09:11 PM   #16
Jayss109
Active Member
Jayss109's Avatar
hey guys, thanks for the info!
Jason
________
spanish girl Cam
Old 11-23-2005, 01:37 AM   #17
409biscayne
Thanks for the info on the tubs , very nice . I've been bracket racing my 68 , nowhere as serious as you , they make great drag trucks . What times are you running ? Where do you race ?
Later.
Can-Am Motorsports
Old 11-23-2005, 01:59 AM   #18
71Dragtruck
Later.
I had it out 2 times in the fall and with the old motor no nitrous ( BB 396 ) ran a best of 12.94 at 102.3mph around 2000 above sea. Never had a chance to run it on nitrous, had a link bar come off a pair of roller lifters and took out my cam. I race at SIR in Saskatchewan Canada, I'm hoping to run in the 11's on motor next year.
Sorry for hijacking the thread.
Sponsored by:
Hard Candy Customs
Old 11-23-2005, 08:01 PM   #19
70c10swb
no brain no headache
70c10swb's Avatar
id like to fit either a 29x15.5 or 31x16.5 on a stock width (70) rear end in a 12 inch wide rim, is this possible? Thats with a 6" drop in the back. Id like them to tuck in the wells nicely and obviosly not stick out.
1996 GMC Sierra z71
1970 SWB 2wd (project)
70c10swb is offline   Reply With Quote
Old 11-24-2005, 05:02 PM   #20
71Dragtruck
Not without cutting, minitubing and narrowing, even with a 7-8" backspaced rim, I would be very surprised if it fit.
Sponsored by:
Hard Candy Customs
Old 11-24-2005, 05:12 PM   #21
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Good info
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-24-2005, 11:04 PM   #22
70c10swb
70c10swb's Avatar
i dont mind tubbing
but looks like its back to the drawing board
1996 GMC Sierra z71
Old 12-03-2005, 10:58 AM   #23
Bowtie67
Bowtie67's Avatar
How wide are the original Tubs? I am thinking of tubbing mine this winter and using these for the tubbing. Mine is a stepside and with my current setup of the 295/50's in the rear I am not getting $hit for traction, 40mph and going to pass someone the truck will go sideways on me without really trying to get into it. I dont want to run street slicks so I am forced to either carry some heavy weight in the rear or put some wider tires on like the M/T Sportsman S/R or the Hoosier Pro Street Radials which are about 18" wide with a 15" foot print.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 12-03-2005, 06:13 PM   #24
71Dragtruck
I think they are around 12", maybe someone with stock ones can measure for you, I never did before I had them done. Mine go to about 3/4" away from the frame rail now. I'm sure they would be more than wide enough for you stepside.
Sponsored by:
Hard Candy Customs
Old 12-03-2005, 06:38 PM   #25
Bowtie67
Bowtie67's Avatar
I stopped by the junkyard today to get an idea of the size of them, inside the bed they measured 10" which will be fine, It looks like in order to put any descent meats on this I will have to narrow both the frame and differential housing in order to use some 15x14" rims. I have spent a majority of the day just doing measurements, options etc. Thanks for the info tho..
2009 Toyota Tundra
