11-20-2005, 11:43 PM | #1 |
Disk Brakes
Ok this has probly been asked before. But what is the cheapest way to get 5 lug disk brakes and drop spindles for my truck? Its a 70 half ton 6 lug drum now.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
11-21-2005, 02:31 AM | #2 |
Re: Disk Brakes
get the spindles from an aftermarket company, and rip off the other parts from a 71-87(i think those years work), but then you have to deal with the rear being a 6 lug rear
-Steve |
11-21-2005, 11:49 AM | #3 |
Old Skool Club
Re: Disk Brakes
Cheapest way is probably to get the front cross-member from a 73-87 and swap it in. You'll find some others on here who have done it.
I can tell you that the route I took wasn't cheap, but it was what I wanted and the money was available at the time. Went with ECE stuff, front and rear, all the goodies, staying with 6-lug pattern. Seems that parts and labor (my cousin cut me a real deal at $300 for all the labor), ran me almost $2K. But, I have a completely rebuilt front end with all the bushings, ball joints, tie rod ends, idler arm, upper/lower control arm shafts, complete disc brake conversion, new springs (front and rear), shock relocaters, shocks, front tires, alignment (factory spec) and adjustable track bar. Drives like a dream, too.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
11-21-2005, 01:53 PM | #4 |
Re: Disk Brakes
I can't see a 71-2 disc brake setup being expensive. $100 should get you what you need.
"You can take the man out of PA, but you can't take PA out of the man" |
11-21-2005, 05:56 PM | #5 |
Re: Disk Brakes
Ya I was at a junk yard and he wanted $200 for a complete set up off a 72 chevy. And the rotors were junk.
I may just get the new rotors and pads and brake lines and bearings from autozone and get some lowering spindles. Who sells lowering spindles for a good price? Thanks for all the help guys
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo Last edited by BowTieMan; 11-21-2005 at 05:57 PM. |
