Slowly getting CRSS...
Does anybody have pics of theirs? And whats the best way to go about it, new spindles? shorter springs?
------------------ Lutz, Fl My Team Website The Heavy Chevy Website ------------------
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
also what are yalls ride height from the top part of the fender well. I have 31'' up front and 32'' out back. so really to level it out i need atleast a 1'' drop in the back.
[This message has been edited by HvyChevy454 (edited April 15, 2002).]
Strongman Garage
![]() Join Date: Apr 2000
to level out a stocker with same size tires you need atleast 2" more drop in back
look for tim christians pics.... he has a shortbed lowered 3/4 ------------------ My Truck pictures www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET" 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 IM me on aol SN= SHAGROLET
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
yes, I would say a 2/4,or a 3/5 would be a pretty level stance.....you may still have a little rake,but not too much.....69
http://community.webshots.com/user/hotrodhorn |
![]() Join Date: Dec 1999
Here you go this is a spring drop only 3-4.
![]() ------------------ 67 GMC Stepside(UNDER CONSTRUCTION) 67 GMC Custom 67 Chevy C-30 |
72 C30 Trailer Queen
Tim,
Great stance! What did you do for shocks on your truck? Did you have to buy new shorter length shocks? Thanks for the info! Chris H
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
How would i be able to tell whether or not the truck already has a spring drop. I'm pretty sure i have the stock springs in it for a 350. But w/ a BB the front squats a little more. but there is still only a 1' difference in ride height front to back. 31 front 32 back
Almost Satisfied
![]() Join Date: Mar 2002
I am having a similiar delimna. I want to drop my 71 but am not sure what I need to do it. I know I want to replace my spindles with the 2.5" lowered ones. Do I also need to drop my spring then or should I stay with a stock height spring. I plan on putting 17" wheels on the truck so that may play into this. So, does anyone have a picture of a truck with a 2.5" spindle drop and a 1" spring drop in the front? I guess the back will then be determined by what I end up doing on the front.
When I started this project I thought lowering would be the easy part! ------------------ 2001 GMC 2500HD Crew Cab Duramax, Allison, 4WD, Love it 1971 Chevrolet 1/2 ton 2WD Short/Step Side. In process of frame off restoration
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Almost Satisfied
ttt
Tim, What size tires are you runnin?
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
Tim, what size wheels and tires are those, its about that time where I get tires and it'd be nice to know what those are. Thanks
1967 was a good year |
Ok guys let me see if I can answer everything the shocks are stock the rims are 15x7 with 3.50 back spacing in front and 15x10 with 4.25 back spacing in rear the tires are 225/70/15 in front and 275/60/15 in rear.
#13 |
![]() ![]() ![]() My truck has a 2.5 inch spindle and a one inch spring. I put stock height springs on since and could not visibly tell much differece. I have a 5 inch spring in the back. I am using KYB gas shocks at all the corners and have 17x8 and 17x9.5. They are wrapped in Nitto 255/50 and 275/50. I personally want to go lower, but my dad and I don't see eye to eye on that. ------------------ http://www.geocities.com/a68rod
Build Thread |
#14 |
Here is a 3/5,with a 1 1/2" body drop.
