Vintage Evil
rear disc conversion
Hey guys
I am sure there has been about a thousand threads on this. I am not rich but would really like to do one of these since my rears are about shot anyway. I have done a ton of searching and have not come up with much. Is there a site or a write up on the parts etc to do this yourself? I do need the ebrake(just incase). Any info, other than some 500-700 dollar kit would be great. I would even consider changing rear ends if that was a more affordable option, plus i could use a little more width. Thanks ![]() |
![]() Join Date: Mar 2004
Re: rear disc conversion
http://steeltechsolutions.com/ how's $89 for the brackets? the rotors will run between 20-40 each and then depending on if you want a parking brake, calipers will run between $50-$300 loaded. i.e. they come with the pads.
ondrew |
Vintage Evil
sweet that is definately an option are there any others?
computer illiterate
pm raggedjim he has done this and it is top notch
72 2wd blazer 72 swb 4x4 |
![]() Join Date: Apr 2005
Try to find a 94-96?? caprice/impala disc rearend (5 x 5 and correct width). You will have to weld on new axle saddles but that is probably the cheapest way to go. I think you can get a rearend for around $200 depending on gears and whether it is a posi unit. Axle saddle are probably less than $40.
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
member #16
![]() Join Date: Dec 1999
Heres another one. Probably not the cheapest but will give you an idea of what needs to be done. John
http://www.classicperform.com/tech_a...kes-trucks.htm
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#7 | |
Vintage Evil
TOTY 2006
Or heaven forbid, grab a factory Ford Nine inch from a Lincoln Continential that has rear disc brakes, buy an adjustable panhard bar with relocation brackets. the nine inch is 5 on 5 lug pattern...
#9 | |
#10 | |
#11 | |
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
Hawaiian Member
I used a four 9 inch out of 66 truck and used Ford Racing (explorer design) brakes that gives the internal PB. I works well and stops on a dime. Like the versatility of using the 9 inch set up to swap gears. I had a lincoln rear with disc brakes but the rear end will not hold up well under serious horsepower.
72 C-10 ProStreet - 331 cu w/ T350 trans 9" shortened w/ disc brakes - Mild body modifications 3/5 drop - More in the works ![]() Last edited by 72wascal; 11-21-2005 at 10:17 PM. |
#13 |
http://67-72chevytrucks.com/vboard/s...d.php?t=178840
Dennis did a great job on shis setup. Check it out!!!!
69 swb stepside, rebuild and upgrade in progress |
#14 | |
Active Member
![]() Join Date: Nov 2005
I am starting to think that it would be easiest and cheapest to simply swap out the entire rear axle assembly, instead of changing out the individual pieces. Also, this would mean newer parts, which means greater parts availability. So, I think I'll lay out my options and bounce some ideas off of y'all. Option 1: Get a complete rear end from a 94-96 Impala SS or Caprice w/police package. Question: What about the rear sway bar? I currently have the kind which attaches to the differential housing, and the Impala/Caprice rear end's don't have 'em. Are there alternative anti-sway mechanisms I can steal from the Impala/Caprice donor car? Or can I have a machine shop weld on some sort of stud to which I can attach the sway bar on the new rear end? (note for those of you considering this option - go sign up on impalassforum.com!) Option 2: Change to a leaf spring rear end. Is this even possible? Can I just get rid of the tracking arms, coil springs, and sway bar? Will the leaf spring based rear ends from the 73-87 or 73-91 trucks fit? (are they wide enough / too wide?) Will the leaf spring u-bolts attach to my frame correctly? Will I need to fabricate new points to attach the shock absorbers to the frame? And what about rear anti sway stuff? Option 2 does seem to have the advatage of updating all my rear end parts to more modern stuff with INSANE parts availability, and it also seems like it would be easier to upgrade to higher bed / towing capacity this way (basically just need beefier leaf springs, right?). Also, I imagine a truck rear end will be heavier duty than an impala rear end. Thanks for you input guys - y'all are an incredible resource! ![]() |
#15 | |
Could also use ECE's track bar re-location kit. |
#16 | |
Jason my 67 GMC has leaf Spring Rear and I dont think I am going to be using my frame once I pull the body off of it for the short bed conversion I was planning....
Soon to be selling all but one, or two... Depends on what the Boss has to say....... 67 GMC Shortbed 454 Project more junk and most of it is for sale |
#17 |
Active Member
67Mach1: Ohh, I'll have to come take a look at that!
![]() Last edited by cell; 01-18-2006 at 09:20 PM. |
#18 |
Thats the Hillbilly way
Here is one I have saved because they also have kits for Dana 60's
http://www.blackbirdscustomtrucks.com/index.html
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
#19 |
Thanks Bill for posting us....
Your going to do what you want., but we are an option and on this board. good luck in your ventures...
Support The Board |
#20 |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#21 |
Active Member
thanks john, that's another potential source to add to my donor list!
#22 | |
#23 |
![]() Join Date: Dec 2004
i sell the prints and templates to make your own brackets,mine use all 4 flange bolts instead of 3 like everyone elses,ive been selling them for 25 lately,let me know...mike
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
#24 |
![]() Join Date: Feb 2004
$25 is a good price for a template. Does yours allow the re-use of the oem e-cable. Do they mount the calipers forward horizontal instead of top?
#25 |
well,there is an ebarke caliper to use,which should retrain your factory cable,the calipers mount straight up,but there is no difference as far as where the caliper mounts to the stopping power,trust me,ive tried about every angle out there,and these seemed to be the best,not only that,it made it easier for people to make there own,pm me for more...mike
