11-21-2005, 04:54 PM | #1 |
Lowering my 69 Shortbed Stepside
I was wondering if there are ways of lowering my 69 without spending 300 dollars on lowering springs? I am wanting to lower it 3 inches front and back.
Thanks for any help you can give me. Bruce |
11-21-2005, 04:56 PM | #2 |
1FINE69
Re: Lowering my 69 Shortbed Stepside
There's always the torch method but it is highly discouraged .
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD |
11-21-2005, 05:10 PM | #3 |
Questionable
Likewise with coil cutting.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
11-21-2005, 05:20 PM | #4 |
I've heard front coil cutting is OK, (not the best). Heating=bad. Cheapest=rear lowering blocks/bolts and cut front springs. I'd post this in the suspension forum.
11-21-2005, 06:13 PM | #5 |
Cutting coils will work, but will stiffen the ride. Check out ECE's 2/4 drop only $379
http://www.earlyclassic.com/catalog.aspx Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
