![]() Join Date: Jun 2003
Completed the swap of the sheetmetal onto the 4x4 frame from the C20 chassis. I now have a lot of new, rebuilt, and fairly new parts left over to sell. For everybody who might be interested, I started replacing parts on the C20 around March of 2002 with all N.O.S., rebuilt original equiptment, and finally quality aftermarket parts (mostly Early Classic Enterprises and NAPA quality) where the first two were not available. The C20 chassis 'wear items' are basically not four years old at the most. The hard work and expense is DONE on all of the items I'm selling. A lot of very nice Christmas gifts here!
**************NOW ACCEPTING BEST OFFERS!*************** 2WD 3/4 Ton longbed frame WITH TITLE and VIN PLATE, No Rust Ever - Sanded, Primed and Painted... 500.00 14 Bolt Full Floater, Detroit Locker, Rear Disk Brakes, 3.73, new rotors, seals, all bearings throughout, races, tight as a drum - no leaks- professionally setup, Spring perches set for coil spring 67-72 .............................. 650.00 (These are selling for 1295.00 plus shipping in the condition that this is in.) SOLD!! 2 Trailing Arms w/PolyGraphite Bushings- Sandblasted, primed and painted. No separation, rust or metal loss ever (Very Nice)..... 200.00 ECE Adjustable Track Bar (Keeps your ass end centered under the truck where it should be)..................................................... 50.00 ECE Heavy Duty Front Sway Bar 1 1/4" (GM did not make a 1 1/4" Bar for a 67-72, This baby is HUGE!), WITH/ ECE Greasable Polygraphite bushings and NEW ECE Frame Brackets.... 125.00 ECE New Front Stock Height C10 coil springs, Small Block) ........ 70.00 New Front Bumper Brackets 2WD ......................................... 30.00 C20 Front Suspension and Crossmember Complete with all newly replaced wear items: Rotors, Bearings, Races, Seals, Tie Rods, Cross Shafts, Ball Joints, Upper and Lower A-Arm Shaft Bushings, etc. (Totally rebuilt) ....................................... 250.00 (Willing to Part Out) 2WD Power Steering Box - Seal Kit installed .............................. 75.00 (SOLD) 2WD Pitman Arm (2 yrs old) ................................................... 30.00 BowTie Overdrives Auto Trans Crossmember - D.O.M. Tubing with clearance for exhaust system to run above or below.......(COOL ITEM)...................................... 125.00 4x4 PARTS NEWLY ADDED: 2 Front 4x4 Hubcaps for 16" Rims. In Excellent Condition........ 40.00 SPICER LARGE FRONT HUB- Factory Style..................... 40.00 700R4 4x4 transmission - Good Rebuildable Trans ......................... 125.00 67-72 Transfer Case Crossmember ........................................... 50.00 14 Bolt Rear Axle can be used for 4x4 applications also. 'Rock Crawlers' love this axle! SOLD!! I'll add more items to the list when I get back into the shop tomorrow. I know there's more........ ![]() Thanks, 72longbed BTW - As the title says, "Chassis and/or Parts for Sale", I reserve the right to sell all of these parts listed in this Thread to any one member who wants everything. FIRST COME, FIRST SERVE. I will list those members who expressed an interest in individual parts in case any deal falls through. Some of these items can't be shipped. I'll work with you the best I can to package up what is shipable. Shipping is additional from 19525. Last edited by 72longbed; 02-01-2006 at 10:18 PM. |
Re: Chassis and/or Parts For Sale
Hey I'm interested in the dana 44 spindles.How can I tell If they are "big bearing"?I need them for a 72 3/4 ton 8 lug.Are they in good condition? Let me know, Thanks.
member
Where in S. Pa. are you? I'm interested in the 350 trans 4x4??? Thanks
John
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide Last edited by olblue60@aol.com; 11-22-2005 at 11:08 AM. |
I would be interested in the part to convert to 3/4. I want to convert one of my burbs to a tow vehicle. It's a 1/2 now.
Can you PM me with a # so I can call you tonight and talk about it? Thanks, Steve |
one set closer
i'm interested in the shock relocation mounts if they are for the rear and for lowered truck thanks up grade
Sorry to take so long to get back, this week has been a busy one at the shop. This is the first chance I've had to sit down at the computer since I posted all these parts.
robhob: The spindles I have are from a 71/72 Dana 44, 8 lug. You can tell the 'large bearing' spindles from the others by the 'shoulders' or 'step downs' between the bearing surfaces. Large bearing spindles have a more dramatic difference between the inner and outer bearing surface diameters. You have first dibbs on the spindles. They are in very good shape. If your Dana 44 front axle is truly a 72, then these are the spindles you need. Dana didn't start to use the smaller spindles on 3/4 ton trucks until 1976. oldblue60: I'm located in 19525. My wife grew up in Silver Spring, Md. You are first in line for the transmission. UP GRADE: The shock relocation kit is for the rear and designed for when you lower one of these trucks. It puts the shock into a much more functional angle after lowering. You have first dibbs on the kit. Happy Thanksgiving to Everybody!! ![]() 72longbed Last edited by 72longbed; 11-28-2005 at 12:04 AM. |
More Good Parts For Sale:
Two piece driveshaft and carrier bearing assembly. Freshly built from all Spicer Heavy Duty 1350 U-joints, yokes, slip yokes and new carrier bearing assembly. Was bolted to a GM 14 Bolt rear and 700R4 trans. up front. This baby is HD, fresh, balanced and complete end to end. Anybody who has ever had a driveshaft built, knows how much money I have invested in this setup!........................................... 200.00 New pair of front disk flexy brake lines. Lines that go from hard line to caliper. 3/4 ton. ........................................................... 25.00 Pair of 76-78 Cadillac Eldorado Rear brake calipers W/ E-Brake built in. These are the ones needed to convert your Eaton HO52, HO72, 14 Bolt, or Dana 60 rear axle to rear disks with an emergency brake that works. May even work with a 12 Bolt axle conversion too. These were very expensive and the e-brake hardware is very hard to find. Complete with all hardware. ....................................... 220.00 Thanks, 72longbed Last edited by 72longbed; 11-24-2005 at 09:49 PM. |
member
Hi
Thanks for the first dibbs on the trans. I'm still interested, but still want to find you on a map.How about a town instead of the zip? Thanks! John
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
John,
the transmission is in Limerick, PA. Can I interest you in that 4x4 700R4 also? Do you know where Paint Branch High School is down there in Silver Spring? 72longbed |
Everybody who grew up in Montgomery county knows where Paint Branch is! A party school, at least back in the 70's
Yep, wife says that's true! She was there from 73-77 and it was a wild time apparently. I would guess most (HIGH) schools in the 70's were 'Party Central' anyway. I know my school was (Class of 75). The three years I was there was like being in a Cheech and Chong movie!
![]() 72longbed Last edited by 72longbed; 11-25-2005 at 12:02 AM. |
Yep, ask her about Walter Johnson HS! After I was kicked out of St John's I transfered to WJ.
Steve |
#13 |
member
Paint Branch?, Sure do! As a matter of fact, a friend of mine teaches there. Its about 5 miles up the street from me.Small world huh!
#14 |
member
Great price on the trans.I looked you up on mapquest. The trip is a little bit further than I had hoped. It looks like just over 3 hrs each way. I guess I'll have to pass, unless you are going a little south in the future and wouldn't mind meeting along the interstate somewhere.
#15 |
member
Hey Steve,
My Mom worked at WJ. I went to Rockville High. I know a few graduates from St Johns.
#16 |
oldblue,
my wife is going to Gainsville, VA and Haymarket, VA on December 10 to see family. If you want I can load the trans. into the back of the Sequioa and you meet her and my son in that area. She travels down that way through Gettysburg, PA. Thanks, 72longbed Last edited by 72longbed; 11-28-2005 at 12:06 AM. |
#17 |
![]() Join Date: Apr 2005
Interested in crossmember. Will it work with 4L60E? Do you have pics? Is someone inline for the shock relocation kit?
thanks,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#18 |
member
Good deal! Sold! Lemme know where to send payment. Thanks!
John
#19 |
Hey I'll take the spindles.PM me with your address and payment details.Shipping to 53105
Last edited by robhob; 11-26-2005 at 10:33 AM. Reason: Forgot to include zip code |
#20 |
one set closer
i'll take them pm me your address and shipping to 38118. thanks up grade
#21 |
Hart_Rob,
the ECE crossmember will fit a 4L60E/4L80E. I don't have a picture now but can get one this weekend. oldblue60, Sent you a PM. I would like a contribution on your part for driving the tranny 3.5 hours south to your area. Whatever is fair. Thanks. robhob, spindles are yours. I'll PM you with the info. I'll get everybody the shipping info ASAP. Thanks, 72longbed Last edited by 72longbed; 11-28-2005 at 12:07 AM. |
#22 |
Front and rear suspensions ARE available right now. This includes the 14 Bolt Full Floater Posi.
72longbed Last edited by 72longbed; 11-28-2005 at 12:00 AM. |
#23 |
![]() Join Date: Apr 2002
Hey 72
I would take the ECE super track bar kit if complete.
72 chevy C-10 swb fleetside,402 BB.700r4,buckets,console.etc. 72 Blazer CST 350,AT, new project 1971 Chevy Nova ,355 SB blow through turbo in works. |
#24 |
Sinister72,
UP Grade is taking the shock re-location kit, so that will leave the ECE Adjustable Track Bar by itself available for sale. It will mount in the stock location and give you the ability to adjust for ride height. You can also purchase the lower passenger side shock mount made by ECE to locate the Pass. side mount to the lower shock support. Not necessary but very easy to do. New Price................ 50.00 Let me know if you want it. Everybody else, I will start taking parts to the UPS depot tomorrow for shipping costs. Thanks to all who have followed through, 72longbed Last edited by 72longbed; 11-27-2005 at 11:23 PM. |
#25 |
one set closer
72longbed i need your address and shpping price so i can send the money. pm me your address thanks up grade
