Old 11-22-2005, 12:42 AM   #1
BowTieMan
BowTieMan's Avatar
Drop springs
Ok I want to do a 3/4 is drop on my 70 long bed. So I was thinking of just getting coils front and back because I can't afford lowering spindles. Will I still be able to do an alignment on it and everything? And will I need lowering shocks front and rear?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 11-22-2005, 01:18 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Drop springs
Yes, you will be able to align the front end with a 3 inch coil drop unless something has been bent in the past.
You don't absolutely need new shocks for this drop, but it will ride much better with some drop shocks and rear shock relocators. It all comes down to how bad you want to save money versus have a real good ride.
Old 11-22-2005, 08:55 AM   #3
70c10
67-72 Addict!
70c10's Avatar
Re: Drop springs
My dad's 70 is lowered with new 4" rear coils and cut front coils (about 2.5" or so) with no problems at all. He had new KYB shocks already on the truck before the drop and it still rides fine now. It looks and handles waaaayyy better with the drop.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
