Old 11-22-2005, 09:50 AM   #1
shelby987
shelby987's Avatar
bed repair
I am new to the body repair world, so bare with me here.
The beds of our trucks (fleetside, longbox here) can be taken apart piece by piece, is this correct? Are they all bolted together, or are there welds that will need to be drilled or cut down? I have one side of the box on my truck that might be easier to pull off and replace than try to patch (back yard body man repair.....almost looks like the panel originally had a toolbox...was that offered on 70 3/4t 4x4's?)....its not on my option sheet though, so maybe this whole panel is a patch panel....that was later patched?
Can you but steel floors still? Mine seems to have taken on a 'wave' design after years of people throwing......god knows what into it.
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 11-22-2005, 10:46 AM   #2
chevyfarmer
chevyfarmer's Avatar
Re: bed repair
Yes the bedsides are bolted on in the front to the front bed pannel, along the floor in front of and behind the wheel tub. The wheel tub bolts to the floor on the outer edge up inside the wheel opening, and obviously to the floor. There should be several welds that you might have to cut at the very back where the bedside meets the floor, and near where the tailgate pivot bracket is. However, if you have a "typical" michigan box, those welds will probably be long gone.
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
