11-22-2005, 12:00 PM | #1 |
Lowering rear
Right now I have 4" blocks in my rear(No remarks) I want to lower it a better way. I am looking at the coilovers from CCP they lower 3" with a 1 inch block total of 4".
First question will I need to notch the frame? They say 4 or more you need it but I have four now and dont need it. Second is the coilover kit and an adjustable tracking arm all I need? Third anyone use this kit and like it? Is there any other benifit from coilovers Ie. better ride more smooth? This is a daily driver. Thanks
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
11-22-2005, 09:33 PM | #2 |
Re: Lowering rear
Anyone running these?
11-23-2005, 08:06 AM | #3 |
Watch out for your cornhole !
Re: Lowering rear
I've lowered a bunch of them 6 inches in the back and never needed a c-notch.
11-23-2005, 07:18 PM | #4 |
Re: Lowering rear
Well, I was gonna say to lower your rear just bend your knees a bit. But then I saw the " no remarks" thing. So as a show of respect I won't say anything.
I got a bench seat baby, you don't have to sit over there. |
11-23-2005, 07:26 PM | #5 | |
Fabricate till you "puke"
Re: Lowering rear
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
