power brake question
The previous owner converted my 68 to power brakes by using donor parts.
My question is How can I tell if it has the proper master cylinder and proportioning valve for the drum drum setup? And does it matter I know the proportioning valve does matter but what about the master cylinder? Seems to brake fine very well for a drum drum I think. Thanks
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Re: power brake question
Anyone
Designated A-hole!
The master cylinder should have two reserviors the same size. The prop valve on the drum/drum should be about 4 inches long and 1.5 high. The prop valve for the disc/drum is a good bit larger if I recall correctly.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
So this setup looks like the correct drum/drum then?
Also does anyone sell these boosters in chrome? Thanks
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO Last edited by 76bonanza; 11-22-2005 at 09:54 PM. |
Designated A-hole!
Yeah that's what it should look like. As far as the chrome, check with the board vendors or maybe summit or jegs.
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
I was surfing e-bay and saw these. If you search collector car and truck parts under brakes and type in chrome power booster it will show a few.
http://cgi.ebay.com/ebaymotors/7-Uni...spagenameZWD9V
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
