Old 11-22-2005, 10:57 PM   #1
Green Machine
Green Machine's Avatar
Auto tilt column to floor shift tilt conversion - is it possible ?
Found an auto tilt column, the PO has sawed off the end under the hood where the auto linkage attaches, I want to use this for a floor shift type also so thats no problem, but I have a floor shift column and was wondering if I could use the shift socket cup from it and install on the tilt column for a cleaner look ? It is also missing the turn signal switch and lever, will the switch from the non tilt column work on it ? Thanks in advance.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-22-2005, 11:13 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Auto tilt column to floor shift tlt conversion - is it possible ?
I've been told that the colar wouldn't work, however, HUCK's old truck had a tilt, and the colar was off a straight column, so there's no tellin what is fact and what is not.
Old 11-22-2005, 11:19 PM   #3
Green Machine
How about that turn signal switch ?? Do they interchange ??
Old 11-23-2005, 12:36 AM   #4
Longhorn Man
I am thinking not... I THINK the tilt one has the light for the PRND21 indicator and IIRC that is part of the turn signal switch assembly.
Old 11-23-2005, 12:54 AM   #5
Green Machine
Since we are trying to finish the PO's attempt to make it a floor shift, I guees we don't care about the indicator light, if the switch will fit and work would be mostly what we are wondering. The good news is he is selling the partially hacked column for only $20, just trying to see if we can make something usable out of it for out floor shift project.
Old 11-23-2005, 01:04 AM   #6
Longhorn Man
lol... didn't even think about that.
Old 11-23-2005, 11:13 AM   #7
Adaptions have been done.But,I have no idea how they went about it.I`d buy it,it`s worth $20 for parts.Is it a truck or van type?
Old 11-23-2005, 12:27 PM   #8
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Yukon Jack just posted his how to last week on here. Shouldn't be too hard to find. He did his by grinding the shifter mount and indicator mounts off and filling them with JBWeld. Looks good. I'm going to try and do mine like you are talking about. Swap the floor shift housing into the column. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 11-23-2005, 02:56 PM   #9
Green Machine
I hope it is a truck type, I think it is but wiil nhve to check it out, for the price I can't go wrong.
