Windshield antenna
My windshield is broke in an arc that starts on the right of the antenna and goes up and through the antenna.
Can this be fixed or will I have to replace the glass to get my antenna working again? |
Happy to be here
![]() Join Date: Mar 2000
Re: Windshield antenna
Unfortunately to repair the antenna you will have to replace the windshield, unless you want to run a convetional antenna. If you don't want to drill holes in your fender you can hook up a metal antenna and stash it under your dash. Even hidden under there it will probably work better than the one in your windshield ever did....
![]() BTW- Welcome to the forum. Post some pics of your truck when you have a chance... ![]()
[QUOTE=N2TRUX]Unfortunately to repair the antenna you will have to replace the windshield, unless you want to run a convetional antenna. If you don't want to drill holes in your fender you can hook up a metal antenna and stash it under your dash. Even hidden under there it will probably work better than the one in your windshield ever did....
![]() that is a great idea i didnt think of that it sure is better than a darn hole in fender thanks this will ad to my to-do list of the truck this is number 1,000.000.000 of thing to do ![]()
square body trucks an addiction or an investment either way they consume all my extra time and money |
Happy to be here
They also make an "electronic" antenna that is desgined to hide in the headliner if you have one. I don't know how well they work though....
I'll post some pics as soon as I get them uploaded to my host.
My truck is still in the "Before" stage. I'm in the middle of replacing it's ragged out 350 with a 454 and it is proving to be more than I antisipated. Just the little nickle & dime stuff. Thanks for the info on the under the dash antenna. I hate to put out the dough on a windshield when there are other, more important things I could use it on. The crack comes up from the bottom of the windshield over the little antenna snap and back down the other side, like a half circle. It looks like the previous owner might have done this when he disconnected the antenna cable from the windshield. I'll try the under dash job. Where can I find such an animal? |
get some solder o drip in that crack and make a connection for the antenna!
I have one of those electronic antenna's in the headliner on my 32 Ford.
Don't waste your time & money. I play CD's in my deuce. You can't beat a steel antenna. Stick it under the dash, or get one of those retracting jobs you can mount under a body panel. Last edited by 78K20; 11-26-2005 at 09:25 AM. |
#8 | |
Happy to be here
