11-23-2005, 02:00 PM | #1 |
Got Horsepower?
electric fan
im looking at putting an electric fan on my truck. will a single 16 inch with 2100cfm be enough to cool it?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
11-23-2005, 03:14 PM | #2 |
18 Till I Die
Re: electric fan
I think so
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
11-23-2005, 05:19 PM | #3 |
Fabricate till you "puke"
Re: electric fan
If your radiator, waterpump,ect is in good shape, you should do ok with that on a mild build. I would try to set up a shroud to mount the fan , rather than through the core like the manufacturer suggests tho.....thats tough on radiators. I run a pair of 14" fans on a home made shroud (1350 cfm ea),with Painless controls & they do fine keeping my 383 cool....... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 11-23-2005 at 05:20 PM. |
11-23-2005, 05:41 PM | #4 |
WTB this ad
Re: electric fan
I run a flex-a-lite 295 series on both of my trucks. It's a dual fan variable speed setup that works great.
11-23-2005, 07:44 PM | #5 | |
Re: electric fan
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-23-2005, 10:36 PM | #6 | |
WTB this ad
Re: electric fan
11-23-2005, 10:55 PM | #7 |
Got Horsepower?
Re: electric fan
thanks, i was planning on making a shroud for it and maybe running a dual fan setup to get about 3200cfm. is the Painless fan control the best one?
11-23-2005, 11:23 PM | #8 | |
WTB this ad
Re: electric fan
11-23-2005, 11:35 PM | #9 |
The LuvShack Garage
Re: electric fan
Asa's set-up is a perfect fit, very minimal bracket fab needed, there are also
some available through the board vendor WES, his are a direct bolt in, but it does not crank out as many cfm's as the one Asa is running, Getting mine in the near future, If you've seen Asa's rigs you will notice he runs these fans in everything he owns, I saw them in person at P.F., and I think they could suck a golf ball through a garden hose, or a cat through a dryer hose
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
11-24-2005, 06:06 AM | #10 |
Re: electric fan
I have a single 16" that is pulling about 2800cfm's and its doing alright. I have one of Wes's shrouds.
11-25-2005, 12:10 PM | #11 | |
Re: electric fan
thanks!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
11-25-2005, 01:03 PM | #12 |
Junior Member
Re: electric fan
I have a metal shroud that we made to fit the rad. then I cut 2 13" holes and mounted the fans and relays to the shroud from a 89 IROC that I'm parting out. the fans are about 12" across. Don't have the truck running yet, but hope to find out if they do the job shortly.
11-25-2005, 01:22 PM | #13 |
Re: electric fan
Farside, I used the original shroud with a 16 inch flex-a-lite, works great... got a couple pix if you're interested... all you do is drill a couple holes in the top and bottom of the stock shroud and bolt it in, then mount the shroud like normal, run your wiring and you're all set...
the fan comes in its own shroud, and the whole thing bolts into the stock shroud... only thing is you need to make sure the rubber gasket on the flex-a-lite shroud fits tight to the radiator core before drilling mounting holes in the stock shroud, so it only pulls air thru the core.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
11-25-2005, 01:30 PM | #14 | |
Premium Level Member
Re: electric fan
touches the shroud so you can secure. If you look at my 77 engine, you can't see the electric, just the stock shroud. I'll post a pic if i can find it. The fan I used was from a mid 90's t-bird(super) and it is two speed. Not the greatest ange, but provides some view of the stock look
69 K5 CST stock- 350, 4speed 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, Last edited by jakeslim; 11-25-2005 at 01:50 PM. |
11-25-2005, 02:03 PM | #15 | ||
Re: electric fan
Thanks guys!
11-27-2005, 01:46 AM | #16 |
Re: electric fan
Hey See Ten
What is the depth of the fans? I only have about 3.5 inches and the flex-a-lite website says that I need 4 inches to run the 295 model setup. Just trying to see if there was some fudge factor in there. Also is that the mounting bracket that comes with the 295 or did you fab that up yourself? Thanks for any help Neal
70 C/10 400 SBC Bowtie Overdrive Level 3 700R4 Last edited by Neal70C10; 11-27-2005 at 01:51 AM. |
11-27-2005, 07:41 AM | #17 | |
WTB this ad
Re: electric fan
