Carb Choke Wiring Question
Where does everyone splice their choke positive wire to? I got my new Edelbrock 1806 and am installing it this weekend but didn't really know where to connect the positive wire for the choke to and was hoping to get some ideas from you guys. PO decided not to hook up the electric choke on the old carb
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over. _______________________ 2006 VW GTI |
![]() Join Date: Sep 2005
Re: Carb Choke Wiring Question
umm i run and wire from the bat to an switch in the truck then to the carb thats how i did and friends truck
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Junior Member
I ran a wire to a switched terminal on the fuse block on my wife's '63 and my son's '67, seems to work well.
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
Some people splice right from the IGN wire on the dizzy.
I like to leave that wire alone. I used the IGN on the fuse block. As long as it is switched power your good.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Thats the Hillbilly way
There is a vacant 12v connection at the fuse box that is powered when the ignition switch is on . That is where I ran the choke wire ,I also placed a fuse in line with it .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , Last edited by Bill72BB; 11-24-2005 at 12:03 PM. |
![]() Join Date: Mar 2003
Some of the factory electric choke set-ups run thru an oil pressure switch.
~Rest In Peace~
i use a circuit breaker relay from the fuse box on the ign also use it on the electric fan with a on/off switch
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
I found a wire the PO hacked off. It may have been a transmission spark control wire. I don't care what it was. It was hot when the ignition was on, not when off so I hooked my choke into that.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
