Shift pointer on tilt column broke
The pointer on my new-only-to-me tilt column is broke off. How in the heck can I change that little guy out? It's a '71 truck column.
jku Cornville, Maine 68 C10 burb 42 Willys MB 46 Dodge WF-32 1.5 ton 53 & 56 Olds' 60 Cadillac 22 Dodge Brothers |
Re: Shift pointer on tilt column broke
You need to take the indicator loose because the pointer clips under it and then the other end just slides into the groove on the column. That way the pointer can slide with the tilt movement.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
ahh, okay. I think I can get a needle nose plier on the end, it broke off down in there, but if it just slides out.....
Thanks for the info.
If the needle nose don't get it maybe you could screw a small screw into the plastic and pull.
