Car O'Holic
Bolt Sizes
What size are the bolts that hold down the bench seat and that hold up the plate that goes under the steering wheel?
Also does anyone know what size o-ring goes on the TH-350 speedo cable so it will stop leaking where it connects to the transmition? |
![]() Join Date: Mar 2003
Re: Bolt Sizes
Bolts are 5/16-18 x 3/4 or 1'' The "o" ring you speak of, if I am on the same page as your description is a really small seal that pushes into the speedo housing and is held in by a wire ring. anyways you should be able to pick one up at a transmission shop. They probably have quite a few laying around.
