11-24-2005, 04:07 PM | #1 |
C10 Club Tennessee
Pulling my hair out...about to give up
I've been trying to get my dash lights and my fuel gauge to work for about a month now. I'm at my wits end. Like an idiot I didn't put in all of the black twist in's that are on the back of the dash for lights. red71cheyenne told me that if I put them in it would complete the circuit-nope. Didn't help, don't know what else to do besides take it to a shop.
Also since I've been messing with this the past week. All of a sudden my battery won't stay charged. I jumped the truck off yesterday and let it run probably 10 minutes. Cut it off and tried to crank it a few minutes later and it barely turns over and does the great click click.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 11-24-2005 at 04:13 PM. |
11-24-2005, 04:39 PM | #2 |
Re: Pulling my hair out...about to give up
Do you have a good ground wire on the metal part of your dash?
72 CHEYENNE 10 SUPER 468/400/3.73 |
11-24-2005, 04:56 PM | #3 |
C10 Club Tennessee
Yes I checked that. It's the black wire with that U-Clip on it.
I just let if run for 30 minutes and cut it off and it wouldn't start back up. So I guess I'll have to check the battery and alt. Also to add to my misery when I hit the brakes my stereo reception gets REALLY crappy.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
11-24-2005, 05:19 PM | #4 |
The LuvShack Garage
Brian, you probably do not want to hear this, but my 70 stepper did
alot of that stuff, Best advise I can give is bad, I went through all the wiring on that truck from one end to the other, took me a few weekends but it was worth it, sorry you are having trouble buddy
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
11-24-2005, 06:06 PM | #5 |
What did you do to your truck right before they quit? New tunes, steering wheel, gage faces? Anything that may help tell you where the problem started?
11-24-2005, 06:39 PM | #6 |
its all about the +6 inches
Sounds like you have a bad ground in all hoesty.
Does the dash light on the heater panel work? Also sounds like a no charge or dead battery as far as not starting. |
11-24-2005, 06:48 PM | #7 |
Junk/Daily Driver Club
Yellow 69 each light on the dash works sepertaly, they are not in series. As for starting check the alt. by removing the battery terminals after the truck is running. If it stays running it OK the battery is junk. Hope this gets you going in the rite direction.
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker. There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened! |
11-24-2005, 07:01 PM | #8 | |
If you must test this way (it isn't good for the alt) then turn on all accessories and then unplug the battery. |
11-24-2005, 07:17 PM | #9 |
Does this back side of the dash board have a printed circut like sheet ? Am not up on this electric much . But could that be something to do with the problem? If so I have one of these I will not be using. Larry
11-24-2005, 07:54 PM | #10 |
Back in the sticks
Sorry Yellow69, I thought the lamps were series, thought that would cure that part of it for you. Did you get to check the pink wire on the plug we were talking about the other night? Also, disconnecting the battery with it running can cause the diodes in the alternator to burn up. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
11-25-2005, 10:23 AM | #11 |
PROJECT 7DEUCE
Are the aftermerkt guages working? How do you have them hooked up? Are they on the same ground curcuit as the clip on dash wire? If the dash lights and guage lights are on seperate grounds try to make them the same ground(same source not same wire) I usally run a wire from the back of the dash pannel to the dash as an extra precaution... Just some food for thought..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
