11-24-2005, 05:14 PM | #1 |
more wiring ?'s
ok so i got all the wiring done, except this little bundle. so far nothing is leading to the a/c compressor, and i thought this might be it, but it seems too short to run over to the passenger side. it has been cut, but this seems way too short. i got a red thick wire for power, a black for a ground, a blue possibly for remote, and a brown with a white stripe, which splits between 2 bundles. inside on the firewall the bundle goes to a relay. anybody know off the top of their head where these go? thanks
11-24-2005, 07:08 PM | #2 |
Junk/Daily Driver Club
Re: more wiring ?'s
What year truck is it?
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker. There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened! |
11-24-2005, 07:13 PM | #3 |
member #16
Re: more wiring ?'s
Looks like voltage reg. wires with plug cut off. Do you have internal regulated Alt?
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
11-24-2005, 09:13 PM | #4 | ||
Re: more wiring ?'s
11-25-2005, 10:31 AM | #5 |
PROJECT 7DEUCE
Re: more wiring ?'s
Before I rewired my truck I had those wires bunded up and taped to the brake support rod on the fire wall...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-25-2005, 12:03 PM | #6 | |
Re: more wiring ?'s
11-28-2005, 01:15 AM | #7 |
Re: more wiring ?'s
My '72 had those wires. I'm pretty sure they connect to a solenoid on the carburetor and a switch on the transmission. The solenoid raises the idle speed when coasting down the road. It's supposed to be some sort of emissions control. There should be a relay mounted on the inside of your firewall near your horn relay that connects to the wires. I removed the relay and the wires and ran a cruise control harness through the firewall hole.
There should be a single green wire for your A/C pump clutch that runs through the firewall over on the passenger side. The connector on the end of the green wire should have two terminals. The second terminal has a black ground wire coming out of it that gets mounted to the A/C pump bracket. There should be what looks like a diode to me connecting the two terminals of the connector. I tried replying to this thread earlier this week, but we were at my parents' house for Thanksgiving and my dad's Mac wouldn't let me reply for some strange reason. Last edited by pjmoreland; 11-28-2005 at 01:17 AM. |
11-28-2005, 11:14 PM | #8 |
Re: more wiring ?'s
hey thanks, that's what i was waiting for. i actually found that green wire youwere talking about yesterday, or the day before, i had it wrapped around the firewall, laying on the cab floor so i didn't see it. i'm leaving those wires off for now, i should recieve a factory assembly manual and shop manual in the mail tomorrow, hopefully i'll get some good diagrams. thanks
11-29-2005, 01:34 AM | #9 |
Re: more wiring ?'s
I have a schematic that shows the carb solenoid wiring. If your manuals don't show it, I can scan the schematic for you.
11-29-2005, 12:15 PM | #10 |
It's a catastrophic success.
Re: more wiring ?'s
A little insight on the AC
11-29-2005, 12:32 PM | #11 |
Re: more wiring ?'s
wow that's nice, where'd you get that?
11-29-2005, 01:03 PM | #12 |
Re: more wiring ?'s
You play on here long enough, you can find anything you want to know about these trucks.
