Old 11-25-2005, 11:03 AM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Headlights with turn signals??
I boughta set of headlights off e-bay a while back but they turned out to be junk does anybody know where I can geta halogen headlight with the little bulb in it to use as a turn signal??? Any help would be great...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-25-2005, 12:55 PM   #2
Deuce
Deuce's Avatar
Re: Headlights with turn signals??
What was wrong with them?? I was going to buy a set too.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 11-25-2005, 01:44 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
They are called "city lights". Hella makes them, probably others do also. One source is http://www.rallylights.com/hella/7in.asp.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-25-2005, 05:40 PM   #4
mac
Active Member
mac's Avatar
Try Yearwood ..... $190 a pair !!!!!
or....try Evil Bay and do a search for a seller named "fatrodder", he's got 'em listed for @ $50
http://cgi.ebay.com/ebaymotors/7-RED...QQcmdZViewItem
mac is offline   Reply With Quote
Old 11-25-2005, 07:35 PM   #5
muddpile
muddpile's Avatar
I think speedway sell em as well, maybe posies or someone too.
muddpile is offline   Reply With Quote
Old 11-25-2005, 11:09 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Yogi's hot rod parts has 'em. They're listed as conversion headlights. They're 7-inch diameter and they include the LED turn signal in the lower part of the lamp. They're $190/pair. They're also on my list of mods for my truck. It's the best way for me to incorporate the turn signals without replacing the bumper with a 71-72 unit, when going to the later grille surround and a bar grille on my '69.
Member Nr. 2770
Old 11-26-2005, 11:01 AM   #7
1972ChevyCheyenne
Found this on Hotrodders sight. The guy goes by the name of Willys36. I don't think it would be legal, but it uses the headlamps as signals.
______________________________________________________________--
Flashing headlight turn signals
I titled this as a pickup project but it is has universal application. I install them on every car I make. It is a circuit that flashes the lo-beam in the headlights so you don't need to install separate turn signals. It is in the vein of blue dots in tail lights - gets lots of comments like, "Did you know that your headlights flash when you turn?!"
To make it you need a piece of aluminum plate about 5 1/2" x 3". I used a 1/4" piece because I had it laying around but go at least 3/16" thick for sturdiness and ability to hold a threaded screw. Electronic components are; 3 Radio Shack or equivalent 50ohm 5w resistors (Photo 1. 10w is OK too if they don't have a 5w. The load is about 2w); two headlight relays (Bosch makes the one in photo 2 which is super compact and has spade connectors, not screws and the mounting bracket. Real popular w/ the hot rod community. Car Quest for sure has them but other parts stores probably do to.); an 8-circuit terminal strip (another Radio Shack item); and misc wire and connectors.
The next entry in this journal has the circuit diagram. Only 3 pictures allowed per entry!
Photo 3 shows the completed circuit board that screws down near your fuse block. The little black wire is grounded to the plate which in my case will be grounded to the steel body of my truck. If your mounting point isn't a ground you must supply a remote ground wire.
I color code my panel to the colors of the wires attaching to it so it is easy to remember where everything goes. You need to isolate the lo-beam wire (tan on GM circuits) going to the headlights to one light and discard the part that used to go to the other light. These carry quite a bit if current so should be 14ga. GM cheaps out with smaller wire but they shouldn't! EZ, Painless, etc., after market harnesses have the larger wire. Then run a second wire (I use yellow) to the other headlight. You need a #14 wire that is spliced into the main power lead to your headlight switch that supplies power whether the headlights are off or on. Remember the low beams must flash in daylight when the lights are normally off. On my circuit board this wire ties into either of the terminals connected by the big red jumper in front of the terminal block. There are normally open and normally closed options on the relay, this wire is hooked to the normally open terminal so when the light switch is off and the turn signals are not engaged, the circuit is open and the lights are off. Turn on the low beams and the relay points close and power flows through this wire to the lights.
Now cut into the old lo-beam (tan) wire near the circuit board and attach the end coming from the dimmer switch (power end) to the far left terminal on my circuit board/diagram. The wires on this are red too but are smaller 16ga since all the low beam light switch does now is power the exciting coil to turn on the headlights and carries 0.25amps max. One side of the coil on both relays are tied to this terminal.
Attach the other end of that old circuit wire that goes to one headlight to the 'out' terminal (tan on my board). Attach the other headlight lead (yellow on my board) to the appropriate connector on the board.
That completes the circuit that will power the lights through the two relays but now you need to hook up the turn signal excitation wires to get the relays to "flash". On GM the turn signal lead wires are 16 or 18 gauge (low current for the small bulbs) light blue for left turn, medium blue for right turn. Sever both near the circuit board and attach the end that comes from the turn signal mechanism to its respective terminal on the board. These no longer power the turns signal lights but power the relay coil to close the points that conduct the current to the headlights. They go to their respective relays and when either is powered by the flasher, it closes the contacts and momentarily tuns on that headlight. Strip out the rest of that wire out to the old turn signal light (or discard it from an after-market harness), 'cause you no longer need lights out there!
Finally, the resistors are tied into the three sides of the relay exciting coil circuit as shown in the diagram in the next Journal entry with the other leads going to the ground.
If you did everything right (I rarely do - usually screw something up and flash left headlight for a right turn - but it is easy to correct!), your low beams should flash "on and off" during the day and "off and on" during the night. Hard to see when your hi-beams are on but then you shouldn't have your hi-beams on when people are looking! Only difference you may notice is that the flasher may be a little slower since their speed is dependent on the current flowing through them and this circuit places a smaller load on the flasher. No biggie.
http://hotrodders.com/forum/journal....age=5&reverse= is part way down the page
http://hotrodders.com/journal_photos...0917727462.jpg
http://hotrodders.com/journal_photos...0917729790.jpg
_______________________________________________________________
Hope this may help some one on a custom
Jamie
72 Chevy Cheyenne 350/th350 LWB
03 Chevy Silverado Sporty Shorty 4.8L
1972ChevyCheyenne is offline   Reply With Quote
Old 11-26-2005, 11:56 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
Thanks guys for the help really help-ful info. Now I just gotta get the $$ for some spendy lights.. Deuce The lights I bought off e-bay were the one you always see in the 67-72 chevy truck search and the housings were plastic and would not hold the headlight bulb in very well just was not happy with pulling out the headlight bulb out every time I wanted to disconnect The wiring from the headlights..
MEMBER #6377
Project "7DEUCE"
