Old 11-25-2005, 12:28 PM   #1
LOWRED84
Powertrax Or Eaton
I Have An 84 Swb Truck With A 12 Bolt Rearend From A 81 Truck. I Want To Replaced The Gears With 3.42's And I Also Want To Install
A Posi Or Limited Slip Unit. Any Suggestions On What Product To Buy And Install?
LOWRED84 is offline   Reply With Quote
Old 11-25-2005, 12:37 PM   #2
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
Re: Powertrax Or Eaton
Eaton, the powertrax works but they are noisy. Alot of people use the powertrax because you can install them with out having to remove the gears. Since you are going to do a gear swap anyways I would use the eaton. I buy all my stuff from Randys Ring and Pinion.
Grande Rojo is offline   Reply With Quote
Old 11-25-2005, 05:15 PM   #3
DroppedZ84
DroppedZ84's Avatar
Eaton, definately. I've had mine in for about 2 years now, and it's never let me down once.
DroppedZ84 is offline   Reply With Quote
Old 11-25-2005, 05:21 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
strange rear end gear or richmond
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 11-27-2005, 01:29 PM   #5
1987 Shortwide
I've got the powertrax, only because I already had a 3.42 12 bolt and didn't want to break it down. It IS kinda noisy when cornering but I don't mind that too much. The true test for me is seeing if it'll really handle that 800+ hp that they claim it will.
When I grenade it I'll put a 9" in anyhow
~Steve~
Friesen High Performance Auto and Graphics
Toy: 87 Shortwide, 406 smallblock with a little boost
My 87 buildup
Daily Driver: 99 Sierra SLE 4X4. Black on Black and harder than hell to keep clean.
1987 Shortwide is offline   Reply With Quote
Old 11-29-2005, 06:10 PM   #6
86 GMG
eaton def. i havent personally ran one yet b/c i couldnt wait to drive the truck so i didnt order i realy regreate that but i am going to put aone in the next gear set i build (f#$^ 9 inch is installed) this way i can have the daily driver single spinner and after an hour or so i can change it to a lower gewar and a carrier to lspin them up together
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
