Old 11-26-2005, 12:48 AM   #1
67 SS
Strange driveshaft ?
I messed up a couple parts that bolt the driveshaft to the transfer yoke.It's a 203 transfer.The driveshaft has normal u-joints on both ends.It uses thick cast caps with threaded bolt holes.The bolts goes through the transfer yoke and threads into the caps.Kinda like a rearend yoke except backwards.What year and model used this set up?
Every 203 I've had or seen used the flat plate mount.
67 SS is offline   Reply With Quote
Old 11-26-2005, 07:15 AM   #2
stan79chevy
stan79chevy's Avatar
Re: Strange driveshaft ?
i dont know the exact years but all of them ive seen like that had the dana 44 front end. i dont know what year they switched to the 10 bolt but im assuming thats when they went to the flange. late 70's
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 11-26-2005, 08:32 AM   #3
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
My 76 K-20 had the same set up it had the Dana 44 front with NP-203. I think that drive shaft is still laying around.
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker.
There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened!
67-72williso is offline   Reply With Quote
Old 11-27-2005, 02:08 AM   #4
1976K5CHALET
1976K5CHALET's Avatar
I believe its allways been saginaw vs. spicer....the later using half straps or ubolts...the saginaw used the plate.
Doug W.
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 11-28-2005, 03:49 PM   #5
67 SS
Thanks.I was getting worried when all I was finding was the flat plate style.I'll start looking at the older trucks.
