Old 11-26-2005, 02:28 AM   #1
cypress TX 72
Saving one 72 at a time!!
cypress TX 72's Avatar
gear change out info wanted
I have been contiplating replacing the 342's in my 12 bolt, and have seen that jegs has a ring and pinion 411 posi set for sale for 495.00...
I have never done this and don't plan on doing it myself, but can someone tell me if I purchase these gears can they be put into any twelve bolt, or is there much more to it. do I order them specifically for my rear-end or are they all the same??
Thanks for your knowledge.
TS
cypress TX 72 is offline   Reply With Quote
Old 11-26-2005, 02:55 AM   #2
68Stepbed
68Stepbed's Avatar
Re: gear change out info wanted
You'll have to make sure they are for a truck 12-bolt. Car and truck diffs are different.
What are you gonna do with the 3.42's? Sell? Keep? I may be interested.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-26-2005, 08:58 PM   #3
john
member #16
john's Avatar
Heres a TTT for you. Someone can answer your question, but you might need a different carrier. John
john is offline   Reply With Quote
Old 11-26-2005, 09:18 PM   #4
Hunter
Lovin' Arizona Since 1961
Hunter's Avatar
My '70 shortie has a 12 bolt posi with 4.11 (coil springs) and I was thinking of going up in gears to get some hiway speed. LOT easier to swap entire diff's...... I'm in Northern AZ. H.
"Religion is like a toothbrush: Everybody should have one, but I don't want yours" - Will Rogers
Hunter is offline   Reply With Quote
Old 11-26-2005, 10:26 PM   #5
neonlarry
neonlarry's Avatar
As long as you get the Posi carrier that goes with those gears you will be OK. Your center carrier will not take 4.11's.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 11-27-2005, 12:18 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Like neonlarry said you will need to change your carrier if you want to go to 4.11's. The carrier usually go from 2.xx to 3.73 and 3.xx to 4.xx. I may be off a bit on my numbers but I think you can see what I am saying.
I am curious why you want a 4.11 gear. Assuming you are running a T350 transmission, and a 28" tall tire you should consider a 3.73. That gives you good low end torque and still allows a moderate rpm at highway speeds.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
