11-26-2005, 04:48 PM | #1 |
700r4 is in.
I just got my truck back with the 700r4 in it. It seams that the gears in the rear end are way to hi (3.07). Going down the road I will be running 55 mph and the rpm will be 1500, at 60 mph it's turning about 1700. My question is what are most people using with the 700r4 in a auto. What is the best ratio to have to get the best gas mileage? The truck is a 71 gmc swb with a new 355 engine.
11-26-2005, 04:53 PM | #2 |
no brain no headache
Re: 700r4 is in.
good all around gear would be 3.73.
expect about 2200 rpm @60 mph
1996 GMC Sierra z71 1970 SWB 2wd (project) |
11-26-2005, 05:12 PM | #3 |
Re: 700r4 is in.
If you are wanting better mileage stay with the 3.07 or go even higher (smaller number). The less RPM you turn the better the mileage.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
11-26-2005, 05:15 PM | #4 |
Re: 700r4 is in.
I was running a 3:73 ratio as well.
11-26-2005, 05:23 PM | #5 |
Re: 700r4 is in.
3.73 cant be beat
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
11-26-2005, 05:43 PM | #6 |
Re: 700r4 is in.
Had a 82 Blazer with the diesel, 700R4 and 3:08 got about 28 mpg on hwy 86 Suburban with 3.54 gears 350 engine 700R4 got about 13-14 hwy currently have a 90 Suburban 700R4 3:73 EFI getting 14 mpg
Dunno about the RPMs never checked have no tach, really dont matter it is what it is heh All 3 meet my towing needs (about 3500 lbs trailer loaded) with the diesel I just took it out of OD when towing, at 70 mph with the 3.73 or the 3.54 I was in OD with the trailer.. |
11-26-2005, 06:30 PM | #7 |
Re: 700r4 is in.
ok guys, here's the deal. you gotta figure your tie sizes, what you're gonna use the truck for (hauling, commuting, etc). I have 3.07 in mine as well, but got some lower profile tires, s othat effectively upped my ratio. 3.07/.9, comes out to around 3.42 or so. big difference in rpm (my .02). Use this guide to calculate tire size ,and multiply by your rear gear http://www.miata.net/garage/tirecalc.html
Remember, with the drag you're pushing, you don't want to load up your drivetrain too much, again, just my .02. with the 700r4, you've got about %30 od, but I'd go with 3.73, or even 4.10. That'll come out to about the same rpm with the same tires as 3.07. It'll be kinda loud in the back though. |
11-26-2005, 06:55 PM | #8 |
Watch out for your cornhole !
Re: 700r4 is in.
I've run 3.73 with overdrive and normal 28 inch tires. It's a good combo, but I like a 3.40-ish ratio better with overdrive.
A great majority of the 88-98 trucks used overdrive and 3.42 gears. It's a great combination. Only problem is that the 67-72 trucks usually had either 3.73 or 3.08 only. A 3.42 would have to be built up.
11-26-2005, 07:00 PM | #9 | |
Re: 700r4 is in.
You have the perfect combination if your daily commute includes the Bonneville Salt Flats. Most people think that installing a 700R4 in place of a TH350/400 will instantly give them great gas mileage. Tire size, engine size, driving style, and driving conditions all play a role in the end result. Most stock 350 engines like to cruise between 2150 and 2500 rpm's. If you decide to change your rear gear to a 3.73 you'll be right back where you started as far as rpm's. Here's an example using my '84 C10 truck. Factory setup 700R4/ 2.73 gears/ 28" tires = 1600 rpm @ 70 mph (A turd from the factory) Today TH350/ 2.73 gears/ 28" tires = 2300 rpm @ 70 mph (Just about right) If I spent $2000.00 (or more) on a 700R4 rebuild and a gear swap 700R4/ 3.73 gears/ 28" tires = 2200 rpm @ 70 mph (Just about right) |
11-26-2005, 07:26 PM | #10 |
I am a Referee of life.
Re: 700r4 is in.
Most of the factory ratio's I've seen were in the 3.42 range.most of them with factory tire size run about 2000-2300 rpms at 65-70 that must be about right or the factory woulda done it difert.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-26-2005, 09:31 PM | #11 |
Re: 700r4 is in.
84 pumpkin, I believe your right, if I put in 3.73 gears I will be back where I first started. Can I put in the 3.42 gears in with the rear end that I have?
11-26-2005, 10:24 PM | #12 |
Re: 700r4 is in.
I have a 700r4 with 3.73 rear end and hate it. I'd trade for your grears in a second. Fulls like I could tow a camper behind me but the truck is not agressive enough for daily/fun driving.
11-26-2005, 11:16 PM | #13 | |
Re: 700r4 is in.
700R4/ 3.40 gear ratio/ 28" tires @ 70 mph = 2000 The 28" tire is a 275/60-15 that I run on all four corners of my '84 C10. Tire diameter has a ton to do with the final ratio so keep that in mind. That same 700R4/3.40 with a 26" tire will give you 2200 rpm's at 70 mph. Last edited by 84 PUMPKIN; 11-27-2005 at 10:33 PM. |
11-27-2005, 01:18 AM | #14 |
its all about the +6 inches
Re: 700r4 is in.
I'll bet a punch in the gut that your MPG will not go up by much... if at all. Lower RPMs do NOT always mean better MPG. your freeway RPM there is simply too low and it is under the curve.
If lower is better was true, then all the new stuff would have 2.50 or so gears.... or a straight one to one and overdrive. It simply wouldn't work. Try the 3.42, that is probably your absolut best bet. Onless you have a motor with gorlla low end torque like a 455, any caddy big block, or a diesel. Last edited by Longhorn Man; 11-27-2005 at 01:18 AM. |
11-27-2005, 09:13 AM | #15 |
laying low
Re: 700r4 is in.
I can offer some experience with the highgeared rears in a daily driver.
My 88 GMC 305, 700r4, all stock 2.73 gear 28" tires I guess the thinking behind my truck being spec'd with this gear was to lower the rpm to increase the mpg. That can be true to a point. It lowered the rpm to the point the engine is lugging and the tranny hunts for the right gear when the slightest headwind or incline is encountered. My first thought was that the engine is just that weak but not so. It is running well below the torque peak. I started running the truck in drive instead of overdrive and the mileage picked up. Running it at 70 or more in drive wasn't a strain either. So for the past 2 years I have been running my truck full time in D, not OD. It still runs cool, has a bit more pickup and is still getting more mpg. The 350 engines will not be as adversely affected by the higher gear due to more available torque and hp. Using the gear calculators I believe the 3.73 would be a great gear for mostly around town and towing things. The 3.42 may be a better choice for mostly highway or more all around driving. The target engine rpm should probably be in the 2,000 to 2,300 rpm range at cruise speed for optimal mileage with the small V8s. I have my eye out for a replacement rear end for my truck. I plan to keep it a while longer so it's worth the investment. Buckman. In your case I don't think the 67-72 trucks came with 3.42 but you can most likely buy aftermarket and have them installed. Or adapt a later model rear end to your truck. You will be happier with lower gears. Until then try running it in Drive instead of Overdrive and see the difference.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
11-27-2005, 10:48 AM | #16 |
Active Member
Re: 700r4 is in.
I just did the swap from a TH400 to a 700R4 (3.73 gears) and I highly recommend the swap. The only problem I have encountered is the performance serpentine pulley kit has slowed down the rpm of the alternator enough where I have to rev the motor over 2000rpm to get it to engage. With the tires I have on I run 2000 rpm and right at 68-70 mph. I am still computing MPG change. I am figuring right now I have gone from 8 mpg to about 14 mpg if I keep my foot out of it. But it's so fun to put my foot in it now. It will roast em all the way to 4th! What a rush!
guyryan100, I don't know what your setup is but I enjoy my truck tons more since the swap. Stoplight to stoplight fun and now it has highway legs too! Last edited by Sonny; 11-27-2005 at 10:51 AM. |
11-27-2005, 01:12 PM | #17 |
Re: 700r4 is in.
Sonny, if you don't charge below 2000 RPM... you need to start looking at your charging system...something isn't right.
11-27-2005, 07:13 PM | #18 |
Re: 700r4 is in.
It seems like a lot of the 88-93GMs or so 700r trucks had 3.42 gears so I think that would be a good one.
11-27-2005, 07:19 PM | #19 | |
Re: 700r4 is in.
11-27-2005, 11:54 PM | #20 |
Re: 700r4 is in.
I have a 700R with 3:73's 28"tire with my driving style the 3:42ish would be keeping the rpms around 2000-2200 I drive a little fast. Lots of open road's and highway mainly. I like the lock up on a toggle switch that save alot of rpms too.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
11-28-2005, 12:23 AM | #21 |
Car O'Holic
Re: 700r4 is in.
side question do you have to have a high hump for the trans?
11-28-2005, 02:10 AM | #22 |
Re: 700r4 is in.
No high hump needed. Just make sure you cab mounts are not old and saggy. As long as the cab mounts are good you should be fine.
11-28-2005, 02:30 AM | #23 |
Re: 700r4 is in.
I have 3.42's in my 94. I bought it that way knowing I was going to lower it and run 275/40/17's in the back. Think it is about a 25.5" tire. The combo was perfect. The low thing got old after a few years and I raised it back up to stock with 275/60/17's. As said it has no power and is always hunting for the right gear, needs 3.73's. One of the things I hate about the 700R4 or 4L60E (mine) is the larger gap between 1st and 2nd. It does not transfer good power for a driver without good tire and gear selection.
Wanted to add that my milage actually decreased with the larger tire as well.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 11-28-2005 at 02:35 AM. |
11-28-2005, 07:47 AM | #24 |
Re: 700r4 is in.
Thangs alot guys, It looks like I'll do like Boog did, I'll run it in drive and change to 3.42 gears when I save up for some cash. This old truck is getting a little expenses put I'm having fun.
11-28-2005, 10:34 AM | #25 |
Re: 700r4 is in.
My 67 has the 350/700R4/3.73 rear. I don't know my tire size, but I turn about 2400 rpm at 75 mph. I get a hair over 15 mpg going that fast. I did a long trip on a slower, mostly no stops highway going 55-60 the whole way, I got almost 16.5mpg that trip. I get about 13 around town. I used to get 11-12 town or highway with my I6, 3spd, 3.73. My 00 Z71 has the 5.3 and 4l80??? which is a .67 vs the 700r4 .70 OD, and the truck has a 3.73. 31" tires and 2300RPMs @ 75 mph and 18.2 mpg. This thread answered my question I was going to ask.... is 3.08 too high.... guess the 3.73 stays....
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
