Old 11-26-2005, 05:33 PM   #1
djtlaz
Bad Carb Or Timing Problem
How can you tell if you have a problem with the timing or the carb is bad. I have a 1995-00 generation 1 350. It seems that I have it timed at about 8 and at times when turning it off it will try to stay on. I have adjusted the carb and timing in many different combinations and have yet to find something that I am comfortable with. Any suggestions?
djtlaz is offline   Reply With Quote
Old 11-26-2005, 07:21 PM   #2
djtlaz
Re: Bad Carb Or Timing Problem
Old 11-26-2005, 08:22 PM   #3
truckdude239
truckdude239's Avatar
sounds like the carb isn't closing all the way when you cut it off
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-26-2005, 08:29 PM   #4
jhow66
jhow66's Avatar
If it is a 1995-2000 it does not have a carb unless engine has been changed. These has TBI and computer controlled.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-26-2005, 08:32 PM   #5
djtlaz
its just the block,,it was original for tbi, but a carb can be used. At least that is what the casting numbers say it is on mortec.com
Old 11-26-2005, 08:35 PM   #6
djtlaz
This is actually what mortec.com says my motor is.
10243880...350...95-00...2 or 4...Vortec truck, Gen.I crate motors and "ZZ4", roller cam, one piece rear seal
Old 11-26-2005, 08:51 PM   #7
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
What type of distributor are you using? Sounds like an ignition thing to me.
(D)
1970 GMC C-25 LWB (middle of frame up)
5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood.
1987 Camaro z28
350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer.
1988 Monte Carlo (Super Stock ashpalt race car)
My Truck
DTerry is offline   Reply With Quote
Old 11-26-2005, 10:01 PM   #8
jhow66
jhow66's Avatar
What kind of carb & dist. are you using? What is the idle speed?
Old 11-26-2005, 10:16 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
It sounds like a condition called "run on". The engine "diesels" when you try to shut it off. In the early-mid 70's, manufacturers were trying to comply with the emission laws and there was a good bit of it going on. So, the manufacturers went to an "anti-dieseling solenoid" that would put pressure on the throttle valve and hold it in the closed position. That was the intent, anyway.
A number of us, who had engines tuned for higher octane gas with lead in it, learned to leave an automatic in gear, when turning off the ignition. Timing that was too advanced for the low/no-lead gasoline, frequently saw this occur.
So, maybe to help, your timing may be a bit too advanced, although mine is set at 10 degrees BTDC. I'm running the original block ('69) with stock compression ratio, an Edelbrock Performer intake with an Edelbrock Q-Jet and headers. The Q-Jet leaned out my fuel mixture, compared to the Edelbrock 1405 that was on it. I didn't encounter any run-on when I changed carbs, but I did have some heat soak problems with the starter.
So, which carburetor are you running? Which intake? I assume you have an HEI distributor. What is your compression ratio? Does your vacuum advance work? I don't th ink you can say that the problem is "ignition" or "carburetor", per se. It is a combination of things that you will have to run through to find the answer. Which plugs are you running?
Member Nr. 2770
Old 11-26-2005, 11:08 PM   #10
djtlaz
I have a 1904 edelbrock 750cfm carb which I think isn't the best for it. I plan on changing to a 1406 600cfm edelbrock. It has a edelbrock manifold I believe the performer series. It is HEI but don't know what kind or voltage. It needs new wires and plugs. I think it does need to be timed higher than the 8 degrees I have it at but I cant keep it from dieseling so I figured it was the carb. My throttle response isn't quite what I think it should be at right now. That's why I think it should be timed higher. I don't know how to test for compression. I am only some what of a weekend warrior in the garage. I try doing everything myself but this one thing has baffled me.
Old 11-26-2005, 11:32 PM   #11
screamin_c102
screamin_c102's Avatar
Djtlaz, I would be surprised if had any throttle response with a 750 Quadrabog wannabe on a nearly bone stock 350. You probably are getting the run on from a comination of excess fuel, poor timing and carbon build-up on the plugs from age and the first two. You should be running a base timing of 10 degrees BDC.
Get yourself a cheap screw-in compression tester and thread it in in place of the cylinder's plug you are testing. DISABLE YOUR IGNITIONCrank your engine over three two four times and read the gauge, repeat the same steps for all the cylinders. Compare your reading and check to see if you have any really low or high cylinders. I would do a "wet" comp test next. You want to squirt a little oil into the cylinder and repeat the first procedure. Compare the "dry" and "wet" results.
Take it light....Bill
screamin_c102 is offline   Reply With Quote
Old 11-26-2005, 11:45 PM   #12
djtlaz
Yeah I know the carb sucks. Just got the truck and when you first get it you think about all the stuff you can do to it. I was trying to salvage a few things on it and I thought I could get the carb to work semi decent but I'm having to much problems so I'm just going to get a new one. A smaller one at that. I'm thinking about getting the performer series package from edelbrock(carb,intake,heads,and cam shaft). What do you guys think of that whole package and how much more horse power should it give me?
Old 11-27-2005, 12:04 AM   #13
screamin_c102
depends....
Old 11-27-2005, 12:10 AM   #14
djtlaz
Thanks screamin c10. That would be nice horsepower to match up to the 700r4 being put in right now
Old 11-27-2005, 12:53 AM   #15
jhow66
jhow66's Avatar
100,000s of stock 350's, 305's, 327's 400sb's. 396's. 402's. 427's,454's etc. have Q-jets. I have rebuilt 100's of these for all kinds of engines. No better stock carb for your street & strip car. Just my 2 1/2 cents worth.
Old 11-27-2005, 12:59 AM   #16
jhow66
jhow66's Avatar
Just a thought--does your HEI have a vacumn advance--does it have more wires coming out of it then the 3 in front-what year truck do you have?
Old 11-27-2005, 01:16 AM   #17
djtlaz
This is my engine per mortec.com
10243880...350...95-00...2 or 4...Vortec truck, Gen.I crate motors and "ZZ4", roller cam, one piece rear seal, I feel a 750cfm is to big for a stock 350
Old 11-27-2005, 06:23 PM   #18
screamin_c102
I just checked the specs on the 1904 you are running. It flows 795 CFM
Regardless of the style, or manufacturer, that is waaayyyy too much carb for a bone stock small block. You might as well mount a toilet on your intake.
I have had better luck with Qjets off road, and in marine applications (they practically run upside down), as well as my GN turboed S10 (don't ask) but for a daily driver I prefer the edelbrocks, if properly tuned.
Jhow66, I didn't mean to insult, You have far more experience than I with Qjets, I don't have the patience to screw with 1 of 'em let alone 100
Everbody has their preference, I just think he is severely over-carbed
Old 11-27-2005, 11:44 PM   #19
jhow66
jhow66's Avatar
No insult taken. Just was pointing out that they can be made to work on many engines.
Old 11-28-2005, 12:25 PM   #20
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I have the 1901 Edelbrock Q-Jet, rated at 750CFM. I, too, am running the stock block and stock compression ratio. Q-Jets are misunderstood by many people. It's not a bad carburetor. Carburetors, in general, have been fingered as the culprit in many cases in which they were not to blame. I have made money rebuilding them because someone else said it needed to be overhauled.
One problem that they have, is leaking fuel from the float bowl, via the plugs in the bottom of the body of the carb, but visible after you remove the throttle plate off of the bottom of the carb. If those plugs are leaking, you'll be getting fuel in the intake, via the leak. That fuel, combined with a lean condition in the engine AND with a "hot spot" in the combustion chamber, COULD cause the run-on condition. This problem will also be shown to cause bad gas mileage and flooding. There are repair parts available that don't require a rebuild.
Member Nr. 2770
