Old 11-26-2005, 06:01 PM   #1
ChopTop
GMC Options ??
I have a 71 GMC fleet short. This truck has the coil springs in the rear. I use to think all GMC's had leaf springs. I am told coils were an option on GMC's. Is this true? Where's the proof? Also this truck has drums not disks and is six lug. Can anyone explain this, and .... where's the proof?
Member of the "Old Farts Club"
ChopTop is offline   Reply With Quote
Old 11-26-2005, 06:16 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: GMC Options ??
If you want "proof"....I caint help, I just dont have a d@mn thing that I feel I need to prove to anybody, anymore otherwise, I might beable to help.... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-26-2005, 07:12 PM   #3
84 PUMPKIN
Re: GMC Options ??
Chevrolet - coil springs & trailing arms were standard - leafs were an option
GMC - leaf springs were standard - coil springs & trailing arms were an option
Proof?
http://www.earlyclassic.com/Tech.asp...=Spring%20Time
84 PUMPKIN is offline   Reply With Quote
Old 11-26-2005, 07:29 PM   #4
uncle
Re: GMC Options ??
Not trying to dispute what anyone else said,but I think if you look at your option sheet you'll see that leaf spring was an option on either. Just what I've found from the trucks I've had. GMC trucks seem to be more prone to have the leaf spring option though.
uncle is offline   Reply With Quote
Old 11-26-2005, 07:39 PM   #5
Re: GMC Options ??
The proof is on the truck`s VIN-Spec sheet on the back of the glovebox door and all them numbers.Did you run down the truck`s serial number to verify the truck`s originality?The year,length,bed type,V8 vs I6,for instance.
Are rear coils listed on option list?What level of trim is listed.does the rest of the truck match?Do you have the build date on the truck.Was it a`70 titled as a`71?What does the truck`s grille look like?Is there a broad verticle cross-bar with black trim in the center,then carrying around the horizontal openings,to around the headlight bezels?Or,is the verticle cross-bar narrower,closer to the same size as the horizontal cross-bars and noblack in the center?
I guess there`s proof for about anything provided all accurate info is there to go on.We need to see what you got to give you what we got.
Your move.
Old 11-26-2005, 08:11 PM   #6
crazy longhorn
Re: GMC Options ??
Look on the top LH frame rail , right around the steer box for the VIN......does it match what is on the cab? is this a 2wd, or 4x4?
Old 11-27-2005, 12:43 AM   #7
Joesjunk
Joesjunk's Avatar
Re: GMC Options ??
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 11-27-2005, 01:07 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: GMC Options ??
I have personally seen more GMC trucks with coils than leafs,a nd NONE of them called for it on the SPID label. I have also seen leafs listed on GMC trucks as optional.
I have also however, seen a couple GMC trucks with leafs and no mention of it on the SPID label.
If your truck is in fact a 71, and it has drums, then they were swapped out. Some one may have used it as a parts truck and slapped there old less desirable stuff onto the parts truck and sold it as a whole. There should be 0 GM trucks in the 10 - 30 range (1500 - 3500 in GMC talk) that ever had 6 lug (talkin 2 wheel drive here) nor with front drums... period.
Either your truck had parts swapped out, or it is not in fact a 71.
Old 11-27-2005, 08:15 AM   #9
Re: GMC Options ??
C`mon back.We`re all here dying to help.Need more info...need more info...need mo...
Old 11-27-2005, 08:42 AM   #10
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
Re: GMC Options ??
Leaf spring was one option on my 70 C-20, also had Dana 60 (4.10).
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker.
There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened!
67-72williso is offline   Reply With Quote
Old 11-27-2005, 09:19 AM   #11
67-72williso
Smile Re: GMC Options ??
I just found some real good info.
Later Willis
Old 11-27-2005, 11:31 AM   #12
roger0080
Re: GMC Options ??
Pic is too small to read anything. Can you give a recap of what it says?
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 11-27-2005, 01:11 PM   #13
67-72williso
Re: GMC Options ??
I`ll try to make bigger.
Old 11-27-2005, 01:22 PM   #14
Longhorn Man
Re: GMC Options ??
I can almost see what it says in some spots.
What does it say, and do you have a high res copy you could e-mail me? (pretty please? cockroach93 @yahoo.com )
Old 11-27-2005, 06:40 PM   #15
67-72williso
Re: GMC Options ??
Longhorn Man, E-Mail sent. If it didn`t work I`ll try again.
Later Willis
Old 11-28-2005, 09:58 PM   #16
67-72williso
Talking Re: GMC Options ??
Proof, GMC 2WD came standard with coil spring rears 1500 & 2500, leaf rear was the option. 3500 leaf spring only. Just ask Longhorn Man he has the info.
Later Willis
Old 11-28-2005, 09:59 PM   #17
Longhorn Man
Re: GMC Options ??
Willis... I was meaning to post this... the attachment didn't work.
Old 11-29-2005, 10:38 PM   #18
Longhorn Man
Re: GMC Options ??
Here is the page.... I have the full page shown, and then a zoomed in cropped version.
Acording to this page from GMC, the coils are supposed to be standard, both 1500 and 2500 trucks.
Old 11-29-2005, 10:59 PM   #19
67-72williso
Thanks Andy
Willis
