Old 11-26-2005, 09:15 PM   #1
truckdude239
truckdude239's Avatar
how do you tell if
how do you tell if your points are going bad? how do you change them i've done the one in an lawn mower before and it never run again (well till i took it to an shop) i want to do an full tune up was was suppose to be getting an full hei setup for free but i guess it fell though haven't heard from the dude its been over an month so i guess i not going to get it. i got an misfire plan on new plugs any recmends on brand new wires cap and rotor buton thinking on new points also any ideas it only misses at sitting still
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-26-2005, 09:22 PM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: how do you tell if
If it a daily driver go to a wrecker and pull a HEI and buy new plug wires and put her in. If its some what of a hotrod look at Pertronics.com or the other brands -Accell , Mallory ,etc
M2c
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 11-26-2005, 09:52 PM   #3
truckdude239
i wnt to switch t hei bad but everyone around here wants between 100 -150 buxs for the distribtor thats not the coil of idon't have alot of money right now with me paying the truck off little by little its not an hotrod just an daily driver that gets me to and fromwork
David fuller
2000 Tahoe 5.3l 378
Old 11-26-2005, 10:09 PM   #4
chops333
to change points youll need feeler gauges and dwell meter pull the points grease the back of new points where it touches the shaft put the points in loosley bump engine around till one of the high spots line up perfectly to the back of the points where you greased them put in feeler gauges not sure about the gap youll have to ask someone else that when you know put in that thickness tighten them down points will have a allen head bolt under the door on the distributor cap when its all back together hook up dwell meter set to specs by turning the allen head screw that sounds confusing but it only takes about 15 minutes i use standard ignition parts a little pricy but will last longer i know a couple places i could get you hei for reasonablelet me know probly 25 or so i work in winston 5 days a week maybe we can get together
chops333 is offline   Reply With Quote
Old 11-27-2005, 01:23 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
is that 100 bucks for a JUNK YARD hei??????
Old 11-27-2005, 02:56 AM   #6
69TowRig
Instead of bumping the engine with the starter, put a 1/2" ratchet and socket on the crank pulley and slowly turn the engine, this will be faster and much more precise. I think I set mine at 0.019"?
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 11-27-2005, 08:11 AM   #7
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
Wink Re: how do you tell if
HEI ? Check with bisquik65, he`s close to you.
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker.
There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened!
67-72williso is offline   Reply With Quote
Old 11-27-2005, 09:54 AM   #8
truckdude239
found an vac line on back of the motor that had an bolt in it looks like my missing trans bolt. it was leaking so i put another hose on it and another bolt with an hose clamp seems to be running right again when i get my power brakes i'm going to steal off this hose for my vac to brake boster
David fuller
2000 Tahoe 5.3l 378
Old 11-27-2005, 10:00 AM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Yikes, that's what I was thinking too
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-27-2005, 10:05 AM   #10
truckdude239
yeah i tolded thewm to go screw them slefs i can get of evilbay cheaper then that
David fuller
2000 Tahoe 5.3l 378
Old 11-27-2005, 01:14 PM   #11
Longhorn Man
yeah... you need a new junk yard.
heck, I've seen BRAND NEW ones go for less than that.
Old 11-27-2005, 03:22 PM   #12
RANDY COX
RANDY COX's Avatar
Over the years my brother kept saying why don't you switch over to HEI and i said why mess up a good thing,that was until i swapped over on my burb 4x4 6 banger and what a difference it made.Made a believer out of me,Oh and best of all got it for free the guy was getting ready to take to junk yard,and also got power steering box from an 83 k5 for free so caint beat that now can ya.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 11-27-2005, 06:52 PM   #13
davidh
davidh's Avatar
You can go to many new parts stores and buy HEI's for $100 new or rebuilt.. Junk yard prices are usually about $25-45 for HEI's. Some A-holes at junkyards try to rob everyone. IF they only new they were shooting themselves in the foot.
davidh is offline   Reply With Quote
Old 11-27-2005, 06:55 PM   #14
Longhorn Man
I guess i am lucky...I refuse to pay 25 for a junk yard HEI, and I can get them all day long. If you are carefull and smart about it, you can get a brand new cap,rotor and coil in there too.
MaybeI should start getting these and e-baying them huh?
Old 11-27-2005, 07:01 PM   #15
truckdude239
yeah you can make some money then touhg ti was doing good lol when junkyard dude offeder to send me one free http://67-72chevytrucks.com/vboard/s...&highlight=hei
been about an month so i know its not comeing
David fuller
2000 Tahoe 5.3l 378
Old 11-27-2005, 07:10 PM   #16
tnblazerk5
User #12137
tnblazerk5's Avatar
give chevye(i think thats how he spells it ) a pm about a hei dizzy he had a few a while back
tnblazerk5 is offline   Reply With Quote
