Old 11-26-2005, 10:03 PM   #1
jakeslim
Premium Level Member
jakeslim's Avatar
Nothing like FOUR drum brakes to freshen your memory.....
of how much I hate doing drum brake jobs I went through put new drums and shoes on all four wheels, and greased up the front bearings.
Such a fun and dirty job. The fun part is doing these on an average every 3 years or so trying to remember when all the springs and levers fall out where they go. Luckily there is another wheel for reference. Once I remembered, it was smooth sailing.
69 K5 CST stock- 350, 4speed
77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's,
jakeslim is offline   Reply With Quote
Old 11-26-2005, 11:30 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Nothing like FOUR drum brakes to freshen your memory.....
Time to swap out a disk front axle...
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-27-2005, 03:25 AM   #3
69TowRig
...and definitely swap the WHOLE THING, don't do the conversion route like I did. $$$
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 11-27-2005, 04:39 AM   #4
jakeslim
jakeslim's Avatar
I actually plan on leaving as is in original form. Its not my daily or otherwise I would convert. I was testing them out this evening and they sure do LOCK up easily I think they are supposed to self adjust ?
Old 11-27-2005, 08:54 AM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Nuthing like 4 wheel lock-up, leaves pretty black marks
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-27-2005, 11:58 AM   #6
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
there nuthing wrong using drum brakes they work just as well as disc if there adjusted right
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 11-27-2005, 12:52 PM   #7
bouncytruck
SKINNY TIRES RULE!
I think you are suppost to drive backwards and step on the brakes to get them to self adjust.
bouncytruck 1972 K5
Old 11-27-2005, 12:56 PM   #8
fastwillie 696969
~Rest In Peace~
its better to adjust them by hand not all e brakes work the same
Old 11-27-2005, 01:00 PM   #9
hotrodhomi
hotrodhomi's Avatar
you need to get them close by hand before they will self adjust.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 11-27-2005, 02:01 PM   #10
jakeslim
jakeslim's Avatar
Looks like I got some reverse driving to do . I believe I got them close with the at install....new rotors and shoes may be the culprit though! I will see what happens. I would hate to lock up and get rear ended!
Old 11-27-2005, 02:18 PM   #11
hotrodhomi
hotrodhomi's Avatar
If they are to touchy you need to back them off my hand. THe self adjust only works to tighten them up.
'66 impala ht
