Old 11-26-2005, 10:18 PM   #1
chevybill
chevybill's Avatar
How to install a harmonic balancer?
I hope everyone had a good Thanksgiving day.
I have my engine cleaned to paint with the POR-15 engine paint kit.
My question is how do you install a harmonic balancer? Do you use the same tool that removes a harmonic balancer? or is there a specific harmonic balancer installation tool?
Also I will be buying a crankshaft pulley and water pump and water pump pulley from summit do I need to purchase the larger diameter pulleys or the smaller diameter pulleys? Should the water pump pulley be smaller so it will turn faster and a larger pulley on the crankshaft?
I realize this is a very elementary question, but I need some assistance on this.
Thanks everyone.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 11-26-2005, 10:21 PM   #2
neonlarry
neonlarry's Avatar
Re: How to install a harmonic balancer?
Rent an installer for free from AutoZone.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 11-26-2005, 11:49 PM   #3
jimfulco
If you can't locate an installer tool, you can use a length of all-thread (7/16" fine thread for SBC) along with a nut, a couple of regular 7/16" flat washers, and the thick balancer washer. The washers & threads should be greased to make it a little easier. I've used a thrust bearing from an A/C compressor clutch tool, but it's not really necessary. Whatever you do, don't try to use the balancer bolt. The threads are not long enough & you might strip out the hole in the crank.
jimfulco is offline   Reply With Quote
Old 11-27-2005, 02:37 AM   #4
A.P.
Black 72 Chevy
A.P.'s Avatar
What I did was to go to homedepot and got a longer bold with the same thread as the one in the harmanic balancer. Also got some washers and it worked great.
A.P.
A.P. is offline   Reply With Quote
Old 11-27-2005, 09:09 AM   #5
70GMCer
70GMCer's Avatar
What ever you do, DON'T use the harmonic balancer bolt to install the balancer onto the crank. I did that, and half way thru, the bolt broke off inside the crank.......bummer......oh, and a lot of foul words came out of my mouth!!!
lol
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-27-2005, 09:20 AM   #6
papawswrench
A.P. - I would caution anyone NOT to just buy a bolt from a hardware store to do this with ! You need a bolt of at least the same grade as the original bolt , just longer . If you get an inferior grade bolt , you triple the likelihood of breaking it off in the crank !
JMHO
papawswrench is offline   Reply With Quote
Old 11-27-2005, 10:09 AM   #7
chevybill
chevybill's Avatar
so you guys are saying there is a different tool for installation and a different tool for removal?
how about some pulley input for the crank and water pump (see the first post)
thanks for all the replies
Old 11-27-2005, 10:39 AM   #8
Sonny
Active Member
As for size of pulleys, you need to consider the operating rpm of the engine. I bought the March Performance Serpentine Belt Kit (Alt, WP, PS Kit) which worked perfect when I had the TH400 installed. I would regularly have the engine turning more than 1800-2000 rpm which is enough to turn the alternator fast enough to start charging. Now that I put the 700R4 in I have to make sure I rev the engine to over 2000rpm to get the alternator to start charging. The engine rarely sees 2000 rpm now, unless I put my foot in it. Not complaining, now I have a reason to put my foot in it!
Sonny is offline   Reply With Quote
Old 11-27-2005, 10:49 AM   #9
A.P.
Black 72 Chevy
A.P.'s Avatar
papawswrench your are correct on using a bolt with the same grade or better. The bolt I used was.
Old 11-27-2005, 04:13 PM   #10
chooch406
Use a good quality grade 8 7/16 fine thread. Clean the crank threads there's a lot of pressure on the bolt as your trying to force the balancer on. Clean and oil the outside of the crank snout and the inside of the balancer. You might have to play around with the number of washers just make sure you have a lot of threads engaged otherwise they'll pull out.This is what you're trying to make on the cheap http://store.summitracing.com/defaul...h.asp&x=38&y=6
I'd start a new post as far as pulleys go.
Mike
68 Gmc 1/2 ton pickup
66 Malibu
87 GN
85 Sub parting out
03 Yukon
chooch406 is offline   Reply With Quote
