11-26-2005, 11:15 PM | #1 |
How difficult is it to put in a cam shaft
I am thinking about getting a performer series package from edelbrock. It has a intake manifold,heads,cam shaft. I haven't ever put in a cam. Is it fairly easy to do?
11-26-2005, 11:33 PM | #2 |
Re: How difficult is it to put in a cam shaft
well to get to the cam you have to:
A: remove intake, and valve covers, loosen and remove pushrods, so you can remove the lifters or the cam won't come out B: remove front of engine, which means crank pully, the water pump, fan, timing cover, timing chain, and more i just can't remember it all. then you put the new one in and bolt on everything. if you're getting new heads, you'll want to dissasemble the engine like this anyways. |
11-26-2005, 11:37 PM | #3 |
I knew what all had to be removed I just didn't know if there was any hidden secrets I needed to know about before doing this.
11-26-2005, 11:41 PM | #4 |
~Rest In Peace~
its not hard if you just set the cam timing to tdc you should be ok try google how to install cam
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
11-26-2005, 11:42 PM | #5 |
Msgt USAF Ret
If I was going to do the package I would do a complete rebuild. Unless you have a fresh rebuild or an engine with low mileage you are going to put a lot of strain on the lower end of your engine. By the time you get all the components off you're changing there isn't much left to pulling the engine and rebuilding it. A fresh bore with new pistons rings etc. and as for the cam it would be best to have a machine shop install new cam bearings before you put that new cam in. Cams aren't hard to install but you have to be careful not to damage the cam bearings and if you have a manual or an experienced friend to help set it up it isn't too hard.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-26-2005, 11:47 PM | #6 |
~Rest In Peace~
11-26-2005, 11:53 PM | #7 |
I bought the truck recently and the the guy said it only had about 10k on it. I believe him just looking at it you can tell it is fairly new. Also when I was under it I saw a bar code from the dealer that was practicly new. It was in a spot that the guy would have had to spend a lot of time trying to clean it do fraud someone.
11-27-2005, 08:19 AM | #8 |
I think the cam bearings are what makes it tough.I would only replace cam & bearings together(and lifters).
11-27-2005, 09:15 AM | #9 |
remenber to replace the lifters with the cam if u use the old lifters they will wear old the new cam like mins then you've wasteed you money just my $.02
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
11-27-2005, 01:36 PM | #10 |
No need to install cam bearings when changing cams.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
11-27-2005, 01:43 PM | #11 |
My personal best is on my 4x4 truck. I had the used cam laying on the work bench in one hour flat.
In my opinion the hardest part is getting the timing chain cover off. On my 4x4 you can lower the oil pan far enough without lifting the engine. I don't know if you can do that on a 2wd. When I built my 383 I put in an Edelbrock 2-piece timing chain cover in case I ever have to put in another cam. (My old 350 used to eat cams for lunch so I'm a bit sensitive there.)
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
11-27-2005, 02:59 PM | #12 | |
Msgt USAF Ret
11-27-2005, 03:49 PM | #13 |
20' Daredevil (Ret)
Here's another guide... http://www.2quicknovas.com/happycams.html
11-27-2005, 11:41 PM | #14 |
Was talking about his low mileage motor. If you are going to rebuild one you would have to put them in anyway if you have it hot tanked.
