Old 11-26-2005, 11:53 PM   #1
gregbr
Senoir Member
gregbr's Avatar
crossover steering???
I saw this listed on a restored/updated 4wd Burb on e-bay....IT HAS AN UPGRADED CROSSOVER STEERING SYSTEM WITH A SECOND STEERING KNUCKLE ON THE RIGHT SIDE AND MAKES IT DRIVE LIKE A NEW 2006 CHEVY TRUCK.
What is this and is it worth doing on a 4wd? Or is he telling a big one. Any pictures if this is worth while? Greg
Here's the listing, it's nice. http://cgi.ebay.com/ebaymotors/Chevr...91810706QQrdZ1
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 11-27-2005, 12:10 AM   #2
ZOOMY
Re: crossover steering???
It's usually done by the off-road guys to get more suspension travel & to help reduce or eliminate bump steer. To make it drive like a new truck though is questionable. On our trucks you basically use a 2wd steering box which puts the ptiman arm parallel to the frame rail. This then allows the drag link to cross over to the other side to an aftermarket steerring knuckle. I'm sure somebody here or on the 4x4 board will come up with a picture for you.
ZOOMY is offline   Reply With Quote
Old 11-27-2005, 01:14 AM   #3
OhioChevy
Crossover steering is usually used on a truck that has been lifted. With
size 36 or bigger tires it is needed to take out the bump steer. On the
truck I am building I have installed a 8" skyjacker lift kit and will be
using 36x15.50x15" mickey t. tires. I used a flat top spindle from
a chevy truck and a late model dodge pitman arm. All of the steering rods
are made using 1-1/4" solid stainless bar with 3/4" L&R hyme joints.
I will be using these wheels with the mickey t. mtz tires instead of the
claws that are on the wheels now.
OhioChevy is offline   Reply With Quote
Old 11-27-2005, 01:39 AM   #4
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
All that tricked out gear and they use cheesy clamp-on battery terminals.
I don't think that listing has near enough pictures, either.
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400.
Founding member of the No Money To Spend On My Truck Club.
When your at Home Depot, you WISH you had gotten an 8 foot bed!
Cat Fuzz is offline   Reply With Quote
