Junior Member
NV4500 swap
I have recently swapped a nv4500 into my 72 K/5. The first transmission I put in made a extremely loud grinding noise in 4th and 5th gear. I called the supplier and they sent me a 2nd transmission. I installed it today and have the same problem but not quite as bad as before.
The adapter kit is an Advanced Adapter bolted to a newly rebuilt NP205 transfer case. It seems strange to me that both transmissions would have the same problem. But I don't have any idea what it could be. The only thing that comes to mind is that in the installation instructions you have to cut off the output shaft and harmonic balancer. Has anyone else had a problem like this, any input would be greatly appreciated. Thanks, Bill |
![]() Join Date: Jan 2005
Re: NV4500 swap
NV4500 needs a not-so-common gear lube 75W90 GL-4 ONLY. Did they come filled or did you put fluid in them? AMSOIL and Castrol make fluid for that transmission. NEVER use GL-5 in that thing.
Also, are you sure that the NP205 that was just rebuilt is not the culprit? Just throwing out ideas here.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
Re: NV4500 swap
No answers for you, sorry.
![]() Any further input/problems encountered/cost/benifits for those wanting to attempt it would be great. Welcome to the board! |
Junior Member
Re: NV4500 swap
69towRig
I did use the correct GM fluid that they recomended in fear of voiding the warranty. No I'm not sure that the NP205 is not the culprit but the fact that the noise only happens in 4th and 5th makes me think transmission. This morning I drove it in low range and still the noise was only in 4th and 5th. I do appreciate any ideas. vtblazer The swap is actually very easy. The only modifications I had to make were installing a block mounted starter, drivelines and the tunnel. Everything else fit perfectly. I would say that the kit is engineered quite well. They originally sent me the wrong bracket to install the 4wheel drive lever but they over nighted the correct one free of charge. This being said I wonder if they sent me the wrong 2-piece set collar. I think this is what holds the shaft that 5th gear is mounted to in place. Anyone else with experience or ideas? Thanks, Bill |
FNG to resto/mod world!
Re: NV4500 swap
Did all the parts come from Advanced Adapters? I want to do the same swap in my Jimmy.
#6 | |
Re: NV4500 swap
Are you running a hydro clutch set up? Or using the stock linkage? Any idea of the overdrive ratio? |
![]() Join Date: Sep 2005
Re: NV4500 swap
I'm about to do this myself.I should have the tranny by the weekend,hopefully.I got a rebuilt tranny with a hydro clutch bellhousing and a spacer to run the late model np205 out of a 1ton. I also got a twin stick kit coming with it.It seems like it will be a simple bolt up deal. What clutch are you using?
01 2500 Duramax,6spd,4x4,Not stock. Estimated 550rwhp/1100rwfp on fuel only. 03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only 67 K10 in many pieces Little Brothers truck 67 K20 Cummins 12V/NV4500/205, D60/Eaton w/ Detroit,37" Xterrains,crossover steering, Future plans,Twins and lots of fuel. |
Junior Member
Re: NV4500 swap
I actually ordered the parts through NV4500.com. All the parts and tech support come from Advanced Adapters. I ordered the new transmission, and adapter kit from them. The kit that I ordered came with a new bell housing so I was able to use my existing mechanical clutch linkage without any modifications. My K/5 already had a 12" dual friction centerforce clutch that I was able to reuse. I'll change it later when I do a motor swap.
I used all the parts and had clearance for everything without having to lower the crossmembers or skidplate. I did have to move them all back approximately 1.5" and I had to do some trimming to get the clearance I needed to install the transfer case mount. Has anyone else done one of these and did they have any problems? I love mine except for the unexplained noise that has yet to be diagnosed. |
Re: NV4500 swap
So,you did the shaft trim?Is the trans rebuilt?I`ve bought two from GM.By the time I bought the second,they wanted an exchange or pay a $500 core.I thought this was strange for a new crate unit from the mfr.It meant to me the secondary or aftermarket had a high demand for these and GM was cashing in.Both transmissions I replaced had a problem up in 4th and 5th.The one just lost 5th with no other symptoms before of after.
#10 | |
Re: NV4500 swap
Lloyd's Drive Train Llc (520) 571-0939 3215 S Dodge Blvd Tucson, AZ Map This guy is a tranny GOD and he can diagnose a lot of stuff on the phone. He has been doing this for 40+ years and his son has taken over, but Lloyd is still there (ask for him specifically) he may be able to simply point you in the right direction. Good luck. How much did this cost (if that's not be nosey) as I'd like to do it in the future on the Blazer. |
Re: NV4500 swap
Old post here but I'm in the "parts collecting" stage of this same swap and was wondering if you ever figured out what the noise was.
Also which version was the NP205? (sm465 10 spline input, th350 27? spline input, or th400 32 spline input) I'll be using the 32 spline input style NP205 and the AA adapter kit #50-0206 and a 96 model NV4500 with a hydraulic clutch setup. I'm just getting ready to put the np205 back together today and I'll be ordering the AA kit asap.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: NV4500 swap
I thought the newer NP205's(86 and up) bolted directly to the NV4500 considering the bolt pattern is the same on both.
I'm only assumeing this though. I have plans for this as well(sometime in the future).Got the NV4500 I thought if you had a long input,32 spline NP205 they would bolt right up to each other?
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 03-16-2006 at 02:14 PM. |
#13 | ||
Re: NV4500 swap
If a person could get one of those circle pattern 205's it might actually bolt up to the NV4500. I'll have to dig out my Advance Adapters booklet and refresh my memory on what they say about them. Quote:
What do you mean by "long input"?
#14 |
Re: NV4500 swap
I got this from ORD's site.
I just added the yellow text. ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
#15 | |
Re: NV4500 swap
![]() My 32 spline 205 has the short input. Any idea what the long input came in/from? If a person could get the long input 32spl 205 and if it would bolt up to a nv4500 that would sure be the way to go.
#16 |
Re: NV4500 swap
According to ORD's site the long 32 came behind the "later model SM465 and TH400 trannies, from about '85 to '91 in straight axle 1-ton trucks"
Here's a link to that page. http://www.offroaddesign.com/NP205tech.htm
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 03-17-2006 at 04:48 AM. |
#17 |
Re: NV4500 swap
Hey billyjo... Every figure out what was causing the noise in 4th and 5th gear?
I just completed an NV4500 swap in my 72 and have the same problem. In 4th and ESPECIALLY in 5th, the transmission makes and awful vibrating noise. It seems worst when the throttle is in a slight deceleration position. JB |
#18 |
Junior Member
Re: NV4500 swap
I think that I did find out what the cause of the problem was and what your describing sounds exactly like what I was experiencing.
The long and the short is driveline angle. I know that it may be hard to believe (I know I didn't believe it) because I made them send me a 2nd transmission and I had the same problem. After I took it to the transmission shop they assured me it was the angle of my driveline. They convinced me to install a CV joint which I did. It made the noise much more bearable but didn't cure it. I didn't like the size of the new CV joint so I ordered a new driveline with a larger CV joint and a disc ebrake and this seemed to make it better yet. I then bought some 8 degree shims and tried that and it got better yet but was still there slightly. This would be a good time to mention that if you go with a CV joint and don't have a body lift it is likely that you will problably have a problem with your ebrake cable coming in contact with the CV joint. Another problem I had is that since I don't have a body lift I had to relieve the floor to make room for the disc and the caliper. Eventually I'll put a false bottom in my center console and nobody will be the wiser. Has anyone else had this experience? I would love to know how you routed the cable for when I redo mine. The angle of my driveline with the CV joint was still 23 degrees and I have been told that less that 12 is what it should be. I plan on having my spring purches cut off and rotating my rear diff and then rewelding them to get to this magic number. I haven't had a chance to get it done yet because I am replacing my 383 with a blown 6.0 but it should be done in the next month or so. I'm sure that this will solve the problem. If I had it to do over I would have just had the purches cut, rotated my diff and rewelded to start with and have been done with it. Hope this helps, Bill
1972 K/5 4x4, Radixed LS1 6.0, 428HP/445TQ, Lingenfelter GT2-3 cam, WCCH 90mm J-Tube, LS2 90mm TB, Stainless Works Headers, NV4500, 4.56 gears, Detroit Lockers, 14 bolt FF, Dana 60, 4 wheel disk Hydro Brakes, dual electric fans, Autometer guages, 4" lift, Zero Rates, Weld Evo Velocity XT8 wheels, 35x12.5x17 Super Swamper SSR's..... http://s72.photobucket.com/albums/i1...tos/?start=all |
#19 |
Re: NV4500 swap
Hey Bill-
Sweet Blazer - where are you at in Washington? Dumb question - but what is the advantage of running a NV4500 - I have just heard of this swap - what is it from? and why it versus a SM465?
-Ben 1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer 1972 K10 - Rust Bucket, TBD 1976 C10 SWB, 350 / T350 My blazer build thread: https://ck5.com/forums/builds/72-k5-...17-update.410/ |
#20 |
Re: NV4500 swap
Biggest thing is the 5th gear over-drive and it's just as tough as the SM465.
#21 |
Re: NV4500 swap
Would it be cheaper to do an Atlas overdrive?
#22 |
Re: NV4500 swap
NV4500's are about 1000-1500 depending, plus the first gear and second are closer in ratio I think. The SM465 is old school for heavy duty trucks, the NV4500 is found in newer 1 tons.
#23 |
Junior Member
Re: NV4500 swap
Igor, I'm in Vancouver, WA I've seen a few or your threads over on K/5 weren't at one time you trying to find a roll cage that didn't block the AC vents and went through the dash? I would like to find a kit for that myself.
BobbyK hit it on the head, 5th gear and just as tough as the SM465 is the biggest advantage. The throw of the shifter and smoothness are another. With it in there it doesn't feel quite so much like an "old truck". I think the downside to using an atlas or gear vendors is the length that it adds. The NV4500 only added about 1 1/2" and with my new motor I was able to reuse all of the stock bolt holes for everything (a big plus).
#24 |
Re: NV4500 swap
Yeah that was me - that is the next step after I get this pig running again (if ever) - so is that NV4500 - what year truck is that from?
Is your rig up and running? Pretty sweet that you got a 6.0 in it - how did that conversion go?
#25 |
Re: NV4500 swap
The NV4500 came in 92 up (present?) 3/4 and 1 ton trucks (GM). They also came in Dodge trucks but I don't know what years.
