Happy to be here
![]() Join Date: Mar 2000
Reverse 4 link
I'm thought this was interesting. I don't quit understand why someone wants to reinvent the wheel, but it is interesting to look at.....
![]() Join Date: Apr 2004
Re: Reverse 4 link
was that done because the frame is lower in front of the axel?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#3 | |
Outlandish Trends - FL
Re: Reverse 4 link
-Bret 67 short-fleet sold! |
Re: Reverse 4 link
I would like to see the whole truck.
Re: Reverse 4 link
I thought reverse setups were fundamentally wrong?
#6 | |
Head Peon
![]() Join Date: Dec 1999
Re: Reverse 4 link
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
#7 | |
Re: Reverse 4 link
#8 | |
Re: Reverse 4 link
We would prob need to know more of the owners intentions before passing any judgements about function.
Hollister Road Co.
Re: Reverse 4 link
If the panhard bar breaks in this type of setup the truck would lose control and most likely flip over because the rear wheels would try to steer in an opposite direction than the front end, its the shopping cart caster effect, run the caster backwards and it becomes unstable. The truck in this setup is being dragged by the rear end instead of being pushed like a normal suspension so the pinion angles go way out of wack as well. If its just a show truck it doesn't make much difference but if it a road truck it dangerous.
#10 | |
its just $$$$$
Re: Reverse 4 link
![]() How do I know? I have had a truck with one on it. and I drove it about 20K miles without it "losing control and turning over" Does it suck? YES does it work? YES Since you probably hate 2 links too, i also had one of those did it suck? YES did it work YES This is probably not a very good setup but come on lets give the guy the benefit of the doubt here we dotn know any of the specifics on this truck |
#11 | |
Re: Reverse 4 link
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
Re: Reverse 4 link
is the ride quality the same?
#13 |
its just $$$$$
Re: Reverse 4 link
the reverse 4 link was on the truck when i bought it, it did work. I never had any problems with it. It was triangulated though.
The 2 link i had i actually installed myself, it worked fine too, but could have been better. |
#14 |
Re: Reverse 4 link
I have a reverse linked truck that was built by the same company that did the truck above. The links on that truck have been engineered to work properly. I have been driving mine for 6 months and i have not yet ran into a problem. Other trucks that have been setup the same, and have had no problems either.
#15 | |
Hollister Road Co.
Re: Reverse 4 link
And your right it does suck and no I don't have a 2 link, I don't hate them ,they have their place and have had for many years and worked well. |
#16 |
Re: Reverse 4 link
do panhard bars break often? I've never seen a broken one, but I've never had this set up either.
#17 |
its just $$$$$
Re: Reverse 4 link
you would really have to be screwing up to break your panhard bar. I have never seen one break, but that doesn't mean that they haven't. anything can break if you dont install it properly.
#18 | |
Re: Reverse 4 link
#19 |
Hollister Road Co.
Re: Reverse 4 link
this helps explain some of the problems with reverse setups
http://www.streetissuecustoms.com/reverse4.html http://www.bagginit.com/research_paper.html |
#20 |
Re: Reverse 4 link
Here is what a good 4 link setup looks like Friend of mine fabbed it up I welded It . This is a Pic Before the CrossMember Was Installed Along With The Bags It's A 94 Isuzu Pickup With a 350/Th400
#21 |
Trucker.
Re: Reverse 4 link
He's gonna pull the driveshaft out of the tranny if that thing has too much lift.
#22 |
-Praise the Lowered-
Re: Reverse 4 link
Here's a reverse setup. (thanks to *****************). Not necessarily a 4-link, nor one of our trucks. But it is a good example of "thinking-out-of-the-box". There are more pictures HERE
JEG
Race-N-Jason ('71 Chevy C-10 LWB 454/TH350) ('07 Dodge Ram 2500, 5.9 Cummins/6-speed Manual) |
#23 | |
Head Peon
Re: Reverse 4 link
#24 |
Re: Reverse 4 link
....my bad....
learn something new everday. I guess I should know what i'm talking about before I speak. Didn't mean to spread any confusion.
Race-N-Jason ('71 Chevy C-10 LWB 454/TH350) ('07 Dodge Ram 2500, 5.9 Cummins/6-speed Manual) Last edited by race-n-jason; 11-28-2005 at 12:49 PM. |
#25 |
Re: Reverse 4 link
Just got my Air Ride Technologies catalog and this was in it!
