11-27-2005, 02:50 PM | #1 |
What are you looking at?
What Spark Plug Wires do you use?
I was getting ready to change the spark plug wires on my 71 GMC and was wondering what wires were the best for the buck. I have a 350 with HEI.
1971 GMC LWB 2005 Honda Element 2007 Honda Fit |
11-27-2005, 02:54 PM | #2 |
Project92 SWB stepside
Re: What Spark Plug Wires do you use?
DELCO or NGK I have had good luck with both.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
11-27-2005, 04:46 PM | #3 |
I usually run Taylors thats what they stock at my local Speed Shop!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
11-27-2005, 04:50 PM | #4 |
I always use taylor wires as well. A few minutes and an ohm meter will show you how superior they are to the crap sitting on the shelves in the auto parts store.Better wires that have less resistance let the ignition parts last a lot longer because they dont have to work as hard to get the voltage to the plugs
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-27-2005, 05:33 PM | #5 | |
User #12137
i got sum taylor wires but havent put them on yet !! there the best but there not cheap |
11-27-2005, 06:04 PM | #6 |
I used Taylors but went to MSD's because of the size of the Taylor boots. They were touching the headers.
11-27-2005, 06:11 PM | #7 |
in my experience the boots on the taylor wires actually seem to hold up to heat a ton better than anything else. though any of em will melt with enough heat the taylors seem to be a little better with dealing with the heat
11-27-2005, 06:22 PM | #8 |
has anyone tried these? They are over 100.00 but I was thinking about trying them on the racetruck! they are numbered on each end and have super low resistance! http://www.moroso.com/catalog/catego...?catcode=39220
11-27-2005, 06:46 PM | #9 |
Its Magically Delicious
over $100.00 for 8 plug wires seems mighty extreme
im running accels .....cost me 12 bucks on ebay .... before that autolites ...
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
11-27-2005, 06:48 PM | #10 |
For cheaper wires I've uesd summits own brand of wires for about $30 bucks and have had really good luck with them.
11-27-2005, 09:50 PM | #11 |
Taylor and Taylor only.......
11-27-2005, 10:13 PM | #12 |
~Rest In Peace~
i use msd wires i used to use accel but ever since i gone to drag racing all i see is msd wires on all top fuel dragster /funny cars /pro stock so if they all using them so will i plus i got the box too
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
11-27-2005, 11:31 PM | #13 |
Ive got Jacobs wires on mine. John
75 GMC C-15 short/step factory 454, lowered |
11-28-2005, 12:34 AM | #14 |
Active Member
If you want cheapies...buy from autozone. They are warrantied for life, even when I burnt them on my headers they still replaced them no questions asked!! Thats a pretty good warranty.
1971 SWB SOLD
11-28-2005, 03:39 PM | #15 |
Before and After
I haven't installed them yet, but I bought a HEI dist and Accell 8.8mm wires at a swapmeet. They are fat.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
11-28-2005, 03:49 PM | #16 |
1968 C20 Vortec Beast
I use the accels on mine, I have been really happy with them. I bought the kit where you crip on the terminals. really solved all of the problems with header clearances for me. Damn Hooker headers... hate them. Going back to Ram Horns.
Ugly or not it still kicks a**! |
11-28-2005, 05:15 PM | #17 |
Taylor sprio pros are good and not to expensive. Plus they have lots of cool colors.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
11-28-2005, 05:53 PM | #18 |
Fabricate till you "puke"
I have been running Accel 8.8 spiral core wires for a 1/2 dozen yrs or so(no troubles). next trip, I plan to run MSD spiral core wires.... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-28-2005, 07:47 PM | #19 |
Taylor Thunder Volt 50's.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
11-28-2005, 09:48 PM | #20 |
PROJECT 7DEUCE
I got msd's on the 454 and cheap summit wires on the daily driver 350..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-28-2005, 10:55 PM | #21 |
I have had Borg-Warner spiral-core wires on my '79 Suburban (stock 350, no headers) for about 5 years, and have had no problems so far. They're ~$35 at Pep Boys.
11-29-2005, 09:48 PM | #22 |
I bought Taylor spiral pro's in blue...cost about $50.00
