Old 07-11-2002, 12:16 PM   #1
dion
72 Cheyenne
dion's Avatar
Cam
I'm getting a better cam for my 350, RV cam in there now, what are you guys running and why?
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 07-11-2002, 02:34 PM   #2
68 with 350 TPI
68 with 350 TPI's Avatar
Cam choice depends on compression,engine size, carb,intake,headers/manifolds,trans, gear ratio etc.
If you could give some info I or someone on the board would be glad to help.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 07-11-2002, 02:54 PM   #3
dion
72 Cheyenne
dion's Avatar
Rebuilt 350, Edelbrock 1406 with performer intake (will switch to Victor Jr. soon) Headman Headders into dual Flowmaster 40's (getting better Headders also) TH350, Dana60 4.10 rear, thanks.
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 07-11-2002, 03:12 PM   #4
bigjimzlll
bigjimzlll's Avatar
if you r going with a vic Jr( which i dont know why) you will want a cam thats in the 280 range......if you tell us some more about your motor..such as the kind of heads..compression ratio i can tell you a little better with a heavy truck and an automatic with out a high stall, its usally best to build for good low end power..stock heads stop working well above 5000 rpm, the vic jr intake works best between 3500 and 7000rpm. try to figure where you will be in rpms most, is this a street ride or a all out racer? take some time and really consider what you want to build...its a lot CHEAPER that way
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 07-11-2002, 03:22 PM   #5
dion
72 Cheyenne
dion's Avatar
Stock heads. I was told by several board members that a vic jr would give me much more HP, that's last on my list at this point. I don't know the comp ratio, I'm taking it back to the shop to find out. First is a bigger cam and 1.6 roller rockers.
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 07-11-2002, 03:32 PM   #6
slam33
slam33's Avatar
1.6 rockers will just make your bigger cam even bigger. Choose the cam you want and run the 1.5's thats what the cam is figured on. As for the Vic, you might find it a bit too much, sounds like your building an Performer RPM motor instead.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 07-11-2002, 05:01 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would stay away from the Vic Jr...ona streed animal anyways. Go for the performer RPM. It is for 1500 - 6500. I have one and am VERY pleased.
You are way better off staying a little conservitive on your cam choice. Especially with your stock heads. Even ported factory heads are nothing compaired to the Vortecs or any aftermarket casting.
I have to live with a bug cam every day, and I am looking forward to the smooth running caddy motor. I like the loping sound, it calls for all car guys at every stop light... "hey man...what the h*ll you get in that old thing?" But I would be happy to go down a few steps. I rag the pee out of mine, but I still hardly ever go over 6 grand.
As for the "heavy truck" statement, if your running a short bed ride, you're probably lighter tham most muscle cars. Long beds are about the same or a little lighter than most of them too.
Old 07-11-2002, 05:19 PM   #8
68 with 350 TPI
I agree ...The Vic Jr. is way too big for stock heads.
In fact you would need 200-220 cc intake ports to work right with it and a cam around 290 duration.
Stay with a performer ,performer rpm, or a weiand stealth at the most.
I would say go with a crane 260 -272 duration at most with near stock compression and a 600 cfm carb.
Trust me it will still have a nice idle if that whats you are looking for.
BTW if you get the flowmasters I would suggest that you also get a H pipe to balance the flow. They only cost about 25-35$ and make a exhaust sound sooooooo much better
Plus can add a few extra hp if put in the right spot.
And stay away from the 1.6 as stated...it will only make the cam act bigger and thats not what you need.
Old 07-11-2002, 06:03 PM   #9
dion
72 Cheyenne
dion's Avatar
What do you guys suggest then? I really want to get this thing faster. First thing everybody tells me is get a bigger cam and roller rockers, it will give you more hp they say. Vortec heads and a better intake was next. These are my hydro cam specs 270 ad duration, 112 lobe speed, valve lift 420, cam lift 280
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 07-11-2002, 06:23 PM   #10
bigvinnie
bigvinnie's Avatar
if you keep your stock heads, you may never achieve your goals...do you plan on racing or just street cruising? What's your budget? Are you running a stock converter or higher stall? Is this a daily driver? What gears are you running? comp ratio and piston type(flat/dish/dome) would be good info to have, especially if you decide to go with different heads...
the cam has to be matched to your components and your specific needs, so you need to eliminate all the unknowns to get a good result, otherwise you could end up worse off... desktop dyno can give you some clues once you have specs for your setup...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 07-11-2002, 07:15 PM   #11
Stepside
Gasser
Stay away from single plane intakes. They suck gas, and don't make power until you get up in the r's. I'm running a 70 LT-1 GM aluminum intake. Several companies have copied this intake. Holley come close with the 300-36. Idle to 7200.
Stepside
:thud 70 sstep tubbed, Muncie, double hump, snowflake,
Stepside is offline   Reply With Quote
Old 07-11-2002, 10:06 PM   #12
Sinister
Between Trucks...
Sinister's Avatar
dude, i'd shy away from the victor...
i got an edelbrock torker, (single plane sorta like the victor), and it's hip out on the highway, but
it's got less low rpm torque going on...
if you got an auto tranny, (specially in a truck), you wanna make torque down low...
if your unsure bout the compression it's probaly 8 - 8.5...try smaller chambered heads, fuelies or something to get the compression up...(or better yet rebuild the bottom end)...how's your tranny? the clutches in mine are starting to go, (slippage)... so off the line at wot the motor's making power but it ain't getting to the rear wheels...
excuse my rambling...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-11-2002, 10:22 PM   #13
lukecp
Formerly yellow72custom
lukecp's Avatar
If i were you, i would invest in a set of Vortech heads. I believe i saw a conversion kit; the heads, gaskets, self-alligining rocker arms, and the bolts; for around $600 from Jim Pace? i believe. That is a steal, considering Vortechs are proably the most powerful production SBC heads ever made, and quite a bit better than several aftermarket heads. Watch out though, with the 64cc combustion chambers, you compression will jump up several points compared to the 76cc chambers on your stock heads. You would proably have to run higher octane gas. Then i would get a Edelbrock Performer RPM Vortech intake, and keep your 1406 carb (jetted a little richer, or course). I would run around the size that 68 with TPI suggested.
BTW, i have heard that Vortech heads, a RPM intake, headers, and a Comp XE268 cam can be good for 380 HP on a 383 stroker, so i dont see why you couldn't get 340+ HP out of your 350.
Good luck!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-11-2002, 10:28 PM   #14
mikep
Used to have a truck
mikep's Avatar
Roller rockers wont gain you a damned thing exept possibly a bit longer valve guide life. Have you ever seen a side by side comparison of roller rockers to stamped steel with grooved balls. The manufacturers claim up to 30 HP gain but have you ever seen their dyno numbers?? Me neither! If it were all that the rocker manufacturers would be sticking it in your face. Instead they make unsubstantiated claims. I like substantiated claims before I spend my money ! Ive used roller rockers before and never seen any seat of the pant difference. Thats why I am using standard rockers now.
The vic is too big. go with the performer rpm or a suitable clone.
No truck :-(
mikep is offline   Reply With Quote
Old 07-11-2002, 10:48 PM   #15
racedvl
racedvl's Avatar
Torque rules the street. Period. If you want seat of your pants fast on the street, exp. in a heavy truck, you need torque. Single plane intakes are for high rpm. Unless your gonna leave every stop sign, or stop light at 4000 rmps, stick to a dual plane.
racedvl is offline   Reply With Quote
