Old 11-28-2005, 01:22 AM   #1
pat
pat's Avatar
Help with dash hacking and new paint
I screwed up and had my cab painted before I cut the dash for a stereo. Whats the best way for me to make a new cd player fit without messing up the paint, burning it, or anything else. I figured a cut off wheel would burn up the paint. Maybe some kind of tin snips tool?
What did you all do to make yours fit. Do I need to weld in the bracket or will the tabs on the deck be enough to support it?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 11-28-2005, 02:19 AM   #2
72MARIO
72MARIO's Avatar
Re: Help with dash hacking and new paint
A sawzall or a hand hack saw wouldwork oky I think. Tin snips would tend to curl the metal..... If you took it slow and cut release cuts you could use tin snips with out distorting the dash. You might want to invest in a set of green coloured handle snips they are a left cut. When you cut the dash try and cut along the top straight the measure down and cut along the bottom. Other wise you will see a small gap above the deck.
Good Luck.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-28-2005, 02:21 AM   #3
72MARIO
72MARIO's Avatar
Is it my eyes or is that hole really tall like bigger than stock?
And about the cage for the deck. All I did was bend the tabs out that seems to be working fine for me.
2005 TAHOE DD
Old 11-28-2005, 02:28 AM   #4
roj2323
rumor has it that a cd player will fit in the stock hole for the heater control and a heater control out of a late 50's chevy will fit in the radio hole. i haven't done this myself but i heard it somewhere. it would be worth a try anyway.
nice color choice BTW.
ondrew
roj2323 is offline   Reply With Quote
Old 11-28-2005, 09:07 AM   #5
Line it out in pencil, then put masking tape around where you cut. A dremel with cutoff wheels does a great job. IT gives you more control and doesn't heat up the area as much. You'll use a few cut-off wheels, but it is worth it. The tape is for when you ooops (and I do too much) and seems to help with it not scrating around the edges as much.
The din insert will support it OK, but I'd recommend the rear brace on the head unit.
Old 11-28-2005, 11:07 AM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
Originally Posted by pat
I screwed up ...
No, you haven't screwed it up...yet
It's a sign that you probably ought to rethink this particular mod
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 11-28-2005, 11:15 AM   #7
72MARIO
72MARIO's Avatar
Delete Plate anyone ?
2005 TAHOE DD
Old 11-28-2005, 12:29 PM   #8
Mudder
Mudder's Avatar
Wear saftey glasses when you cut...........
Mudder is offline   Reply With Quote
Old 11-28-2005, 01:38 PM   #9
pat
pat's Avatar
I thought u might chime in
Good ideas, I forgot all about my Dremel tool, and I have dozens of wheels left.
What is the rear brace? this come with the head unit, or do I need to find one? Otherwise Ill just use the tabs.
72Mario, I dont think the hole is anything but stock.
Old 11-28-2005, 01:42 PM   #10
pat
pat's Avatar
I learned to wear safety glasses after a mishap with carburetor cleaner. Ouch
Old 11-28-2005, 01:47 PM   #11
Most decks come with a little metal strap about 6-8 inches long and a stud on the back of the head unit. Just run the strap from there to the firewall or dash.
Old 11-28-2005, 09:27 PM   #12
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You could go with a delete plate and the din in the glove box or you could do as the pics below show..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-28-2005, 10:05 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I used a hack saw blade helb by a pair of vice grips.
It DOES look like your hole is already hacked... looks twice as tall as it should be, if so.... you'll have problems.
Old 11-28-2005, 10:14 PM   #14
kelsfine69
18 Till I Die
kelsfine69's Avatar
Dont Hack it ...Do this
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 11-28-2005, 10:20 PM   #15
Longhorn Man
hack it... it's just an old truck, and you'll never want to go back to a booring AM static sounding radio again anyways. AM sucks.. it's a fact of life.
Besides, it's just metal.
Old 11-28-2005, 10:32 PM   #16
kelsfine69
18 Till I Die
kelsfine69's Avatar
That truck looks too nice to Cut up, besides why advertise just so some kid can steal it
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 11-28-2005, 11:20 PM   #17
pat
pat's Avatar
The decision to hack has already been made, nothing will change my mind about that.
I thought my dash was original still, but after looking at the before paint pic of my cab, looks like it was cut. My truck isnt with me so I cant check. But heres the cab before paint. Hopefully the hole wasnt cut too big.
Old 11-29-2005, 01:13 AM   #18
Longhorn Man
way too big. The opening should be 2/3 that tall.
Old 11-29-2005, 01:27 AM   #19
724wdcopper
graphic designer
724wdcopper's Avatar
all is not lost... a filler panel (backer if you will) can be fashioned ( i used aluminum ) to occupy the entire radio area and cut out what you need. i used automotive double sided tape to attach it. worked like a charm. btw, my hole was not too big, but you could see the knob indents, and i didnt like that...
724wdcopper is offline   Reply With Quote
