1 pc window kit
How hard is it to install the 1 pc window kit in a 71 and can you get them for less than $349.95.
Re: 1 pc window kit
They install is shown on the Brother trucks web site.
You have to remove the door not a biggie if your in the middle of a resto. You aslo have to hack up your old vent windows. Now to get the kit to operate to my level of expertise I am still not really happy with the operation. BUT I was aware that the window wobbles could be a problem when I purchased the kit. At high speeds the tend to blow out of the track and you have to use your hand to pull the window in while the other hand is rolling it up. The front channel needs to hold the glass tighter that would solve the problem.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Re: 1 pc window kit
I got the kit from TIM CHRISTIAN he was cheeper that the others when I bought the kit 2 years ago.
Re: 1 pc window kit
so your old vents are unusable after the install? No going back.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Chance
![]() Join Date: Sep 2001
Re: 1 pc window kit
Are these kits worth the trouble to install and do they operate properly once they are installed? I am in the middle of a restore with the doors off and ready to be primed. I do not want to use the factory mirrors for a 1967-72 so filled in the mirror holes. In any event, are these worth their price, time to install, and operation? Please let me know.
Chance
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
Re: 1 pc window kit
So it sounds to me that they are not worth the time and money, is this correct?
Re: 1 pc window kit
Well it's not a 100% perfect operation kit in my opnion. I needed new glass and all weather stripping anyways. I am sure if I had the time and could track down a diffirent front channel weather stripping that would make the kit work alot better.
Like the window goes up and down fine makes the truck look diffirent than the others around here it's just not everytime you want to just roll the window up it goes where it's supposto. The vents are junk all you have left is the old glass wing window. I think you can go back to a vent window if you want to there is just a brack thats missing. The guy on the board who has a orange 4x4 went back because of the lack of air flow with out the vent windows. I didnt have a problem with air flow in the cab this summer. If you decide to get the kit and you in the middle of a resto there are a few areas that I missed and would like to have welded up to make the kit look like it was there from the factory. Nobody said anything it's just a small indent I would have like to see smoothed out.
Re: 1 pc window kit
Mario here is my dlemia. My truck is done as far as paint and such. I am inbetween 1 peice kit or electric conversion I dont want to do both. My main complaint with the vents is the whislting otherwise my vents are brand new. So if it were you in my position which would you do?
Thanks just need a little help deciding.
Re: 1 pc window kit
I was going to go with the one-piece set as well so I did a lot of research on it. I have physically seen and operated 3 sets of one-piece windows and all three wobbled when rolling up and down, one of them had the problem like 72MARIO has where you had to "assist" the window up to keep it on track. Maybe there is a way to prevent this, like 72MARIO said with a firmer front track??? Who knows....I do not want to throw down $300 to have a less than smooth operation after spending sooo much time just trying to get everything else on the truck right.
Don't get me wrong here, I REALLY like the look of the one-piece windows, it's just that there needs to be some kind of "kit" that makes them work properly. 76bonanza - IMO I would just go with the power option. My $.02 Mike Last edited by BigMike; 11-28-2005 at 03:14 PM. |
TOTY 2006
![]() Join Date: Dec 1999
Re: 1 pc window kit
I have the one peice windows and power window motors for them, but have yet to install them. I will be using a second seat of doors to build this setup off the truck first, and then will do my doors (they have already been painted.) I have seen several of these trucks with the windows, but only one set that worked perfectly. The guy took his time, and has no tracking problem or wobble with them. Will spend more time checking out his doors once I get to that point. (right now, bedwood is being varnished and is taking up the space in my garage)
Project Junkie! Fishing Poor!!
Re: 1 pc window kit
There are 2 componies producing those window kits. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Questionable
Re: 1 pc window kit
Are both just as poor with the window track? Surely someone must make a decent kit?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#13 |
Re: 1 pc window kit
John,
I spent 3 nights on my drivers door trying to get the window to toughen up it's the front channel for sure I had a close look at it tonight and that the problem. There is nothing more you can do to correct the problem. Bononza, It really depends on what you want to see. If you like the way the truck looks then go power. I would never put power in my truck I like that there is one less thing to break. As for wind noise unless the winds are gusts over 90KM I have had no problems.
